skipsophrenic Posted September 2, 2009 Posted September 2, 2009 I managed eventually to fix the drawing through about 5 Audits 3 puges and 7 recovers, but i havent got a clue what i did before hand, has anyone got any ideas with these error messages? Quote
ReMark Posted September 2, 2009 Posted September 2, 2009 What is the source of the drawing? Did it contain any AEC objects? Any clue to the technical problem referenced in the last line you blacked out? A search of the AutoDesk website for SCANDR 40 came up blank. Still using 2008 as it says in your profile? Quote
skipsophrenic Posted September 2, 2009 Author Posted September 2, 2009 What is the source of the drawing? In house drawingDid it contain any AEC objects? nope Any clue to the technical problem referenced in the last line you blacked out? It was just relisting the filepath and drawing name A search of the AutoDesk website for SCANDR 40 came up blank. same here, checked there first before posting Still using 2008 as it says in your profile? yep, i'm Still using 2008 Quote
ReMark Posted September 2, 2009 Posted September 2, 2009 It's a mystery to me. Internal glitches in the software? Quote
skipsophrenic Posted September 2, 2009 Author Posted September 2, 2009 I have no idea, the problems gone for now, but i keep expecting to turn around at a critical moment and then bang, loose me work. Quote
ReMark Posted September 2, 2009 Posted September 2, 2009 Did you happen to receive any error messages regarding missing language support files while working with the drawing? Quote
mdbdesign Posted September 2, 2009 Posted September 2, 2009 Try:??? In Windows Explorer, right-click on a drawing file. On the shortcut menu, click Enable/Disable Digital Signature Icons. Clear the Validate Digital Signatures and Display Special Icons check box. Restart the system. Quote
skipsophrenic Posted September 2, 2009 Author Posted September 2, 2009 Did you happen to receive any error messages regarding missing language support files while working with the drawing? No i didn't it was just the three i showed you above Try:??? In Windows Explorer, right-click on a drawing file. On the shortcut menu, click Enable/Disable Digital Signature Icons. Clear the Validate Digital Signatures and Display Special Icons check box. Restart the system. I'll try that tomorrow mate Quote
