asos2000 Posted June 9, 2008 Posted June 9, 2008 Is there a lisp draw a line in each layer and adding a text with the layer name? Attached an image showing my request Quote
LCE Posted June 9, 2008 Posted June 9, 2008 Could do it in vba, or even vb.net if that is acceptable. If you specifically want lisp then you will have to wait for someone else. Cheers Quote
asos2000 Posted June 9, 2008 Author Posted June 9, 2008 Both are ok can that file be ocx im trying to avoid loading the macro thanx LCE Quote
LCE Posted June 9, 2008 Posted June 9, 2008 Extract attached zip. in acad type -vbarun then enter "directory\DrawLays.dvb!DrawLays" where directory is the directory to which you extracted the dvb Let me know if you have any problems. I haven't added any error handling yet so if you cancel it will give an error. Cheers Quote
asos2000 Posted June 9, 2008 Author Posted June 9, 2008 Arch_Eric i didn't get it is it an AutoCAD command, or what Quote
Arch_Eric Posted June 9, 2008 Posted June 9, 2008 I screwed something up in my code...here's the revised version... (defun c:layerlegend (/ osm ortho clayer celtype cecolor start-point line-length text-height *error*) (defun *error* (msg) (setvar "osmode" osm) (setvar "orthomode" ortho) (setvar "clayer" clayer) (setvar "celtype" celtype) (setvar "cecolor" cecolor) (princ msg) ) (defun mfp (pt pa) (list (+ (car pt) (car pa)) (+ (cadr pt) (cadr pa)) (+ (caddr pt) (caddr pa)))) (setq osm (getvar "osmode")) (setq ortho (getvar "orthomode")) (setq clayer (getvar "clayer")) (setq celtype (getvar "celtype")) (setq cecolor (getvar "cecolor")) (setq start-point (getpoint "\nSelect point to start legend: ")) (setvar "orthomode" 1) (setq line-length (getdist start-point "\nEnter length of line or click end point: ")) (setq text-height (cdr (assoc 40 (tblsearch "style" (getvar "textstyle"))))) (setvar "osmode" 0) (setvar "clayer" (cdr (assoc 2 (tblnext "Layer" T)))) (setvar "celtype" "ByLayer") (setvar "cecolor" "ByLayer") (command "_line" start-point (mfp start-point (list line-length 0 0)) "") (command "-text" (mfp start-point (list 0 1 0)) "0" (getvar "clayer")) (while (setq layer (tblnext "Layer")) (setvar "clayer" (cdr (assoc 2 layer))) (setq start-point (mfp start-point (list 0 (- 0 (+ text-height 4)) 0))) (command "_line" start-point (mfp start-point (list line-length 0 0)) "") (command "-text" (mfp start-point (list 0 1 0)) "0" (getvar "clayer")) ) (setvar "osmode" osm) (setvar "orthomode" ortho) (setvar "clayer" clayer) (setvar "celtype" celtype) (setvar "cecolor" cecolor) ) Quote
Arch_Eric Posted June 9, 2008 Posted June 9, 2008 Code assumes you have a default text height in your style. Quote
LCE Posted June 9, 2008 Posted June 9, 2008 See attached. Error handling added with a few other tweaks. Quote
asos2000 Posted June 10, 2008 Author Posted June 10, 2008 Thanx Mr. LCE that what I am locking for. Arch_Eric at first Sorry for miss understand, my mother tongue is Arabic second thanx for the lisp The lisp is OK, but its effected for current layer only not for all layers Quote
LCE Posted June 10, 2008 Posted June 10, 2008 Thanx Mr. LCE that what I am locking for. You are welcome. Quote
sprinkle Posted June 30, 2011 Posted June 30, 2011 I know this is an old thread, but LCE (or any one else that saved it) I would love to have this lisp file if you still have it. Thanks! Quote
Lee Mac Posted June 30, 2011 Posted June 30, 2011 Maybe something like this? ([color=BLUE]defun[/color] c:legend ( [color=BLUE]/[/color] df i ln p1 pt sp ) [color=GREEN];; Lee Mac 2011[/color] ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] pt ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify Point for Legend: "[/color])) ([color=BLUE]setq[/color] ln ([color=BLUE]getdist[/color] [color=MAROON]"\nSpecify Length of Lines: "[/color] pt)) ([color=BLUE]setq[/color] pt ([color=BLUE]trans[/color] pt 1 0) i -1 sp ([color=BLUE]*[/color] 1.5 ([color=BLUE]getvar[/color] 'TEXTSIZE)) ) ) ([color=BLUE]while[/color] ([color=BLUE]setq[/color] df ([color=BLUE]tblnext[/color] [color=MAROON]"LAYER"[/color] ([color=BLUE]null[/color] df))) ([color=BLUE]entmakex[/color] ([color=BLUE]list[/color] ([color=BLUE]cons[/color] 0 [color=MAROON]"LINE"[/color]) ([color=BLUE]cons[/color] 8 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 df))) ([color=BLUE]cons[/color] 6 [color=MAROON]"ByLayer"[/color]) ([color=BLUE]cons[/color] 39 0.0) ([color=BLUE]cons[/color] 62 256) ([color=BLUE]cons[/color] 10 ([color=BLUE]setq[/color] p1 ([color=BLUE]polar[/color] pt ([color=BLUE]*[/color] 1.5 [color=BLUE]pi[/color]) ([color=BLUE]*[/color] ([color=BLUE]setq[/color] i ([color=BLUE]1+[/color] i)) sp)))) ([color=BLUE]cons[/color] 11 ([color=BLUE]polar[/color] p1 0. ln)) ([color=BLUE]cons[/color] 370 -1) ) ) ([color=BLUE]entmakex[/color] ([color=BLUE]list[/color] ([color=BLUE]cons[/color] 0 [color=MAROON]"TEXT"[/color]) ([color=BLUE]cons[/color] 7 ([color=BLUE]getvar[/color] 'TEXTSTYLE)) ([color=BLUE]cons[/color] 8 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 df))) ([color=BLUE]cons[/color] 6 [color=MAROON]"ByLayer"[/color]) ([color=BLUE]cons[/color] 39 0.0) ([color=BLUE]cons[/color] 62 256) ([color=BLUE]cons[/color] 10 p1) ([color=BLUE]cons[/color] 40 ([color=BLUE]getvar[/color] 'TEXTSIZE)) ([color=BLUE]cons[/color] 1 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 df))) ([color=BLUE]cons[/color] 370 -1) ) ) ) ) ([color=BLUE]princ[/color]) ) Quote
phani_sai Posted July 27, 2012 Posted July 27, 2012 Searching for LISP draws lines in each layer alongwith text of layername and layerdescription Quote
phani_sai Posted July 30, 2012 Posted July 30, 2012 Hi Lee Mac, Searching for LISP draws lines in each layer alongwith text of layername and layerdescription. Quote
BIGAL Posted July 31, 2012 Posted July 31, 2012 Our other Civil software has this as a default option but with do blocks as well, grid, so you end up with a wall chart maybe version 2 ? Quote
Organic Posted July 31, 2012 Posted July 31, 2012 Our other Civil software has this as a default option but with do blocks as well, grid, so you end up with a wall chart maybe version 2 ? Which civil program is that? Quote
BIGAL Posted August 1, 2012 Posted August 1, 2012 Civilcad has been in it since the 80's also dump your library styles as text files manipulate and reload I would like to see a CIV3d user do that in less than a month. Gave up on changing ours since supplied by Cad dealer it must have taken him months to set up. If it burped give it a style. Quote
