CADnewbie Posted August 28, 2009 Posted August 28, 2009 I continuously have issues with AutoCAD fonts; in particular, Times New Roman will appear bold and fuzzy on one text item (doesn't matter if it is mtext or dtext) in the same document and crisp and smooth in another item (both items have same properties and the Match Properties command doesn't work on them). Also Arial font will print poorly to PDF (even at 1200 dpi; characters are thickened and uneven; most notable in the "i"s and "l"s). Properties of both text items appear to be correct. Can anyone explain the issues to me? Does AutoCAD really use True Type fonts? Quote
chelsea1307 Posted August 28, 2009 Posted August 28, 2009 have you checked the z values of the text with the issues? Quote
CADnewbie Posted August 28, 2009 Author Posted August 28, 2009 OMG! That worked! Never in a million years did I think it would...How about the Arial font problem??? Do you have any ideas? Quote
chelsea1307 Posted August 28, 2009 Posted August 28, 2009 did you check the z values of those ones too? Quote
chrisdarmanin Posted August 29, 2009 Posted August 29, 2009 here try this... i once tried making a tutorial on the subject http://i217.photobucket.com/albums/cc243/chrisdarmanin/4.gif?t=1251531534 Quote
Tankman Posted August 29, 2009 Posted August 29, 2009 Thank you chrisdarmanin for the link. Excellent tutorial! Quote
chrisdarmanin Posted August 29, 2009 Posted August 29, 2009 thanks feel free to distribute it as much as you want Quote
CADnewbie Posted August 31, 2009 Author Posted August 31, 2009 chrisdarmanin that fixed the problem! Thank you! You saved our company from having to do a major overhaul on the fonts we used in our AutoCAD drawings!!! chelsea1307 changing the "z" value for the Arial font didn't work...but definitely thank you!!! for the "z" value with the Times New Roman font! Quote
