rdane1010 Posted August 17, 2009 Share Posted August 17, 2009 I am learning rhino coming from other nurbs software and am a bit perplexed by how to add points to a surface. I have found the tool that allows you to add points which basically adds a horizontal line with a few points to a surface.. however I can't figure out how to add more points along this horizontal line.. it just has its set number based off the surface.. is there a way to do a perpendicular "add points" to go in the other direction or to add more points to that horizontal line? I hope I am making sense, for horizontal I mean if it is a lofted surface made of 2 end curves that are oriented vertically (as I realize it wouldn't always be horizontal). thanks for any help so I can get this figured out. Quote Link to comment Share on other sites More sharing options...
