kkleinchester Posted August 17, 2009 Posted August 17, 2009 I loaded ADT2010 today been switching back and forth between 2010 and 2009 and noticed that my design menu tab is gone in 2010. I loaded autocad classic a long time ago so it has nothing to do with that, I have found the toolpalettes with them just not my nice little tab that muscle memory needs. Any help is appreicated. Quote
CADMASTER1128 Posted August 17, 2009 Posted August 17, 2009 I do not have 2010 currently loaded on this PC, I do at home so I will double check... I have attached a picture that I have previously loaded. AutoCAD 2010 has a differant UI (user interface than 2009). That could be why you are missing the design menu tab. Quote
CADMASTER1128 Posted August 17, 2009 Posted August 17, 2009 One more thing I would like to add, the now called "Application Menu" is a lot cleaaning and runs smoother in 2010. Quote
kkleinchester Posted August 17, 2009 Author Posted August 17, 2009 Yeap, a couple months ago I got past the ribbons and loaded acad.cui which gives you your main menubar. But this is the first time that I am designing a 3d model in 2010 and hate the fact that they have change it. Quote
CADMASTER1128 Posted August 17, 2009 Posted August 17, 2009 kkleinchester said: Yeap, a couple months ago I got past the ribbons and loaded acad.cui which gives you your main menubar. But this is the first time that I am designing a 3d model in 2010 and hate the fact that they have change it. Well most people don't like the ribbon. That is why I still use ACAD 2008 Architecture. Quote
kkleinchester Posted August 17, 2009 Author Posted August 17, 2009 I figured away around it. I loaded through menuload my 2009 aca-design.cui and it seemed to work perfectly. I guess they didn't change commands enough just the menus. Quote
CADMASTER1128 Posted August 17, 2009 Posted August 17, 2009 kkleinchester said: I figured away around it. I loaded through menuload my 2009 aca-design.cui and it seemed to work perfectly. I guess they didn't change commands enough just the menus. How did you load it into ACAD 2010? Quote
kkleinchester Posted August 17, 2009 Author Posted August 17, 2009 menulaod- browse to 2009, support, enu- change the file type displayed and hit ok. apparently there is not much of a difference in the menu styles between 2009 and 2010. THey just forced the ribbon issue. Atleast there is a fix for that. Quote
ReMark Posted August 17, 2009 Posted August 17, 2009 I thought you could go up to the QAT, use the down-arrow and load the menu bars from there. Is that right? Quote
kkleinchester Posted August 17, 2009 Author Posted August 17, 2009 didn't work for me. I had to manually do it. Quote
CADMASTER1128 Posted August 17, 2009 Posted August 17, 2009 ReMark said: I thought you could go up to the QAT, use the down-arrow and load the menu bars from there. Is that right? He is talking about the design tabs, not the QAT... Quote
ReMark Posted August 17, 2009 Posted August 17, 2009 Ahhhhhhhhhhhhhhhh........................tab. Gotcha. Oops and thanks. Quote
CADMASTER1128 Posted August 17, 2009 Posted August 17, 2009 ReMark said: Ahhhhhhhhhhhhhhhh........................tab. Gotcha. Oops and thanks. Welcome... Quote
