Collecting ViewPorts in a Drawing Using VB.NET
SeanT...one additional question...
Once I find the widest viewport...how do I set it as the current active viewport?
Here's my current routine...it works nicely to move through all layouts and all viewports in each layout, reportingthe viewport centerpoint as it moves through the drawing...
But when it hits this line... objAcad.ActiveDocument.ActivePViewport = PVport ...everything comes to a screeching halt.
Here's my little routine...
Dim Entity As AcadEntity
Dim VPcenter AsObject
Dim PVport As AcadPViewport
Dim lngObjectID AsLong
Dim CurrentLayout As AcadLayout
Dim PageLayouts As AcadLayouts
PageLayouts = objAcad.ActiveDocument.Layouts
objAcad.ActiveDocument.ActiveSpace = AcActiveSpace.acPaperSpace
objAcad.ActiveDocument.MSpace = False
'For Each Item In Me.lbAutoCADTabs.SelectedItems 'layout tabs are collected and shown in a listbox
ForEach CurrentLayout In PageLayouts
objAcad.ActiveDocument.ActiveLayout = objAcad.ActiveDocument.Layouts.Item(Item)
lngObjectID = objAcad.ActiveDocument.ActivePViewport.ObjectID
ForEach Entity In objAcad.ActiveDocument.ActiveLayout.Block
IfTypeOf Entity Is AcadPViewport Then
PVport = Entity
If lngObjectID PVport.ObjectID Then
VPcenter = PVport.Center
MsgBox("The center of this viewport is " & VPcenter(0) & ", " & VPcenter(1), , "View Port Center Example")
objAcad.ActiveDocument.ActivePViewport = PVport 'fails miserably here
'objAcad.ActiveDocument.SendCommand("zoom extents ") '...I use this to test if focus has been given to the viewport
EndIf
EndIf
Next Entity
'Next Item
Next CurrentLayout
I need to focus on a specific viewport in order to begin working with the entities shown therein.
Thanks SeanT,
Pete
  • Replies 26
  • SEANT
    15
  • PellaCAD
    10
  • Lee Mac
    2
Posted Images
What if you placed this line just before that line:
objAcad.ActiveDocument.MSpace = [color="Blue"]True[/color]
One of the lines of code commented out in your example seems like it should cause trouble with this active line of code.
Edit: Must be a typo. The example at AUGI has that line commented out as well.
Not a typo...(it works really nicely to move through all the layouts of a drawing)...
The line that is commented out is a For-Next loop...I use that to cycle through the members of a pre-populated listbox...
In my code above (in an effort to isolate the problem, I temporarily commented that For-Next loop out), I'm building a collection of all layouts and moving through each layout (except "Model")...then cycling through all the blocks on that layout, searching for the vPViewPort that matches my width criteria...
When it finds the correct PViewPort, it's time for the action to start.
Your suggestion to insert "objAcad.ActiveDocument.MSpace = True" seemed to work at first...but then when we moved to the next layout, the program failed at the same place as before..."objAcad.ActiveDocument.ActivePViewport = vp"
So my question remains...What is the correct way to assign the current ActivePViewPort?
(Thanks to both SeanT and the Editor for reviewing my situation...)
Here's the code I'm testing (it's using the pre-populated listbox)...
PrivateSub OK2()
Dim objLayout As AcadLayout
Dim layoutBlock As AcadBlock
Dim ent As AcadEntity
Dim vp As AcadPViewport
OriginalSpace = objAcad.ActiveDocument.ActiveSpace
ForEach Item InMe.lbAutoCADTabs.SelectedItems 'all the tabs are listed in this listbox
objAcad.ActiveDocument.ActiveLayout = objAcad.ActiveDocument.Layouts.Item(Item) 'this works nicely
objLayout = objAcad.ActiveDocument.Layouts.Item(Item)
'If objLayout.Name "Model" Then
If Item "Model"Then
layoutBlock = objLayout.Block
MsgBox("LayoutBlock.Count = " & layoutBlock.Count)
x = 0
DoUntil x = layoutBlock.Count
ent = layoutBlock.Item(x)
Debug.Print("x = " & x)
IfTypeOf ent Is AcadPViewport Then
'vp = CType(ent, AcadPViewport)
vp = ent
If vp.Width > 24 And vp.Width
[/color]MsgBox("vp.OwnerID = " & vp.OwnerID & vbCr & _
"vp.Width = " & vp.Width)
objAcad.ActiveDocument.MSpace = True 'line per CADTutor SeanT suggestion objAcad.ActiveDocument.ActivePViewport = vp 'error occurs here - do not know why - 25AUG2009
EndIf
EndIf
x = x + 1
Loop
objAcad.ActiveDocument.ActiveSpace = OriginalSpace
EndIf
Next Item
ExitSub
OK...here's another ViewPort related question...
How do we determine the source layout of a viewport? (The layout upon which the object viewport resides.) What method tells us this info?
As background information: Each layout has it’s own pviewport, active when in paperspace and MSpace = False. While in this “Main” layout pviewport the size and position of the other “floating” pviewports are accessible. This main vport is always the first object in a layout’s Block. This means it can easily be avoided while iterating a layoput’s block by starting at LayoutBlock.Item(1).
If the view of a “floating” pviewport requires modification then change MSpace = True and activate that viewport.
When switching to another layout it is probably advisable to first switch back to MSpace = False.
  • 2 weeks later...
How can you activate a specific viewport??
I've isolated the item number of the viewport (based on the viewport width)...but how can the item number be used to specify the current active viewport?
What is “item number”? Is it the ObjectID or the viewport’s identification number(as employed by the system variable CVPORT)?
I would have thought that the coordinated use of MSpace = True/ MSpace = False along with:
would allow for viewport activation.
I’ve seen your posts on other forums and imagine the lack of a “cut and dry” response to the question is a bit frustrating. The problem, I think, is that you are essentially using a mixed code base with INTEROP. There probably hasn’t been enough work in that area by enough people to easily elicit the answer.
