psyfr3ak Posted May 19, 2008 Posted May 19, 2008 hello i have a picture with a diagram, and i want to scale it diferently on X and Y axe. maybe with extend? if this is the command please explain me how. thanks Quote
Shiloh Posted May 19, 2008 Posted May 19, 2008 or you could insert it as a block and deform the x-y coordinates at insertion Quote
Hoozin Posted May 19, 2008 Posted May 19, 2008 If you know what scales it needs and you're talking about putting in a raster image, you can choose 1-Dimensional scales on the insertion prompt. If it's something else, block it and change the X and Y Scales in the properties window. Quote
Tiger Posted May 19, 2008 Posted May 19, 2008 Noticed that the scaleaxis.lisp has been remove, so here it is a agian - no idea who the author is and it changes everything to lines but it is a simple way to scale everything in one direction. ;;;SCALEAXIS.LSP ;-------------------------------------------------- ; ERROR TRAPPING ;-------------------------------------------------- (defun errtrap (msg) (cond ((not msg)) ( (member msg '("Function cancelled" "quit / exit abort")) (command "undo" "") ) ( (princ (strcat "\nError: " msg)) (command "undo" "") ) );cond );defun ;-------------------------------------------------- ; MAIN ROUTINE ;-------------------------------------------------- (defun c:scaleaxis (/ *error* *ss1 bspt ax mult refpt refdx newdx) (command "._undo" "end" "._undo" "begin") (setq *error* errtrap) (setq ss1 (ssget)) (setq bspt (getpoint "\nSelect basepoint: ")) (initget "X Y Z") (if (not (setq ax (getkword "\nSpecify axis to scale: <X> ")) );not (setq ax "X") );if (if (not (setq mult (getreal "\nEnter scale factor or <Reference>: ")) );not (progn (setq refpt1 (getpoint "\nSpecify reference length: ")) (setq refdx (getdist refpt1 "\nSpecify second point: ")) (setq newdx (getdist refpt1 "\nSpecify new length: ")) (setq mult (/ newdx refdx)) );progn );if (setvar "expert" 2) (setvar "explmode" 1) (command "._-block" "SCALETEMP" bspt ss1 "") (command "._-insert" "SCALETEMP" ax mult bspt "0") (command "._explode" "last" "") (command "._-purge" "blocks" "SCALETEMP" "n") (setvar "expert" 1) (command "._undo" "end") (princ) (*error* nil) ) 1 Quote
LCE Posted May 19, 2008 Posted May 19, 2008 As others have said, block it, set axis scale and then explode it if you need. Quote
stianhaugli Posted May 30, 2009 Posted May 30, 2009 Hi, This is my first post in your forum :-) I see this is becoming a rather old thread, but i'd like to mention a Lisp we've called "fit.lsp". it works with autocad 2000 - 2010, and it quite neately solves the problem. We wrote this little piece long ago, and I thought I'd share it You can download it from our site. (i just got blocked by your forum saying only users with 9 posts or more can post weblinks, so here it is - in Morse Code) 3xw dot xordesign dot com and click the Toolbox. maybe someone (with the magic 9) could re post a proper link? I havent "kelvinated" the lisps as i dont mind you guys reading the code and are sharing under one condition: Do Not remove the credentials (please?) Pleaes dont look at the rest of the site. we dont have much time to update it .. best STIAN Quote
PatientWolf Posted April 18, 2011 Posted April 18, 2011 At least with Mechanical Desktop, you can use the comand AMSCALEXY. Select the object to be scaled. Then follow the command prompts to independently enter the X and Y scaling factors. I find this so useful, I am surprised it is not included in the menus. Quote
PatientWolf Posted April 18, 2011 Posted April 18, 2011 To keep a value just use a scaling factor of 1. Quote
netsonicyxf Posted April 25, 2012 Posted April 25, 2012 The website http://www.xordesig.com isn't available anymore, a nyone has that Fit.lsp? Quote
ReMark Posted April 25, 2012 Posted April 25, 2012 You're lucky I'm such a pack rat. FIT.lsp.txt Download the file to your desktop. Right-click on it and use the RENAME command to remove this portion of the file name and you are good to go. You know how to load a lisp routine in AutoCAD right? Quote
anthpro Posted April 21, 2017 Posted April 21, 2017 I have an image with a small skew, so I have rotate my image and calculated the correct x- axis scale in order to remove it. When the scale is set to 1 (or a number bigger than 1.01 or smaller than 0.9999) the base point is in the correct position. When I set the scale to 1.001, my base point moves! (the base point is on the cross-hairs, shown with a blue dot) Quote
