JerryG Posted August 11, 2009 Share Posted August 11, 2009 When I pull a profile from either a line (quick profile) or creating an alignment and then creating a profile from surface I go to click where to place the profile and I get nothing? All my layers are turned on. I know that the surface exists. My profile is withen my boundary. I have many other profiles already in the dwg. Is there a setting possibly that limits the amount of profiles that are shown??? Thank you for any help you can provide, this one is causing grey hairs! Quote Link to comment Share on other sites More sharing options...
spittle Posted August 11, 2009 Share Posted August 11, 2009 In profile view properties under profiles tab there's a checkbox called 'Draw' is that checked? Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 11, 2009 Author Share Posted August 11, 2009 Thanks Spittle - but I am in 2010 and dont have that option. At least not that I can find? I looked at the profile styles and there is nothing there. I beleive its probably some weird setting since the drawing crashed and now the profiles dont show up. Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 11, 2009 Author Share Posted August 11, 2009 Well I did find a check box for draw and they are all checked but still no profiles? Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 11, 2009 Author Share Posted August 11, 2009 Update; I found the profiles. It is placing them roughly 2000 + feet away from where I specify on screen where they should be placed. Anyone know of a variable to control this? Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 12, 2009 Author Share Posted August 12, 2009 So it turned out it was as simple as turning my UCS back to World! (I think I may start leaving my UCS icon on from now on) 1 Quote Link to comment Share on other sites More sharing options...
Muniirah Posted July 15, 2019 Share Posted July 15, 2019 I cannot view the surfaces from wgich to add or select when creating a profile for existing ground. Help please. (P.s had created an alignment already and it shows the alignment but cannot show any surfaces) Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted July 15, 2019 Share Posted July 15, 2019 Just to eliminate the obvious, have you created the surface? Are you sure the surface and the alignment are in the same place? You can verify the extents of your surfaces in the Prospector. As always, the more information you can give us, the better we can help you. 1 Quote Link to comment Share on other sites More sharing options...
