Convert Cogo Points
I have a large number of Cogo points created from a Civil 3D surface. I want to convert them to regular AutoCAD points (x,y,z) and save as a *.dxf file.
How can I do this?
Thanks
I'm not completely sure what you want to do, but if you turn on the display of "Points" in your Surface Style, you can use the Surface Utilities to extract the points. This gives you a normal Autocad point at every vertex of the TIN.
  • 3 months later...
  • 2 weeks later...
Do those same points have a valid Z coordinate, or did some demon back when convert them all over to Z= zero just for a quicky plot?
Wm.
