Can't extrude in autoCAD 2004
Can anybody help i've been using autocad 2004 for a few years now but today for some reason i can't extrude. If i draw a polyline box and press extrude it tells me "a 3D solid must be selected " Then says "No solids detected".
I've tried creating a region but still no joy.
Any ideas? and why is this all of a sudden a problem?
Thanks
If the full warning is:
A 3D solid must be selected.
No solids detected.
Select faces or [undo/Remove]:
Then the button alluded to with
press extrude
may be mapped to the SolidEdit Extrude, not the standard _Extrude command. As a test enter _Extrude at the command line then pick the pline box.
Got it thanks!!
Must be having an off day!! i was selecting solidedit extrude but was doing all morning for some reason. Standard extrude does the job just fine. thanks
