I have the student version of Autocad Mechanical 2009 and when plotting the drawing, the text " produced by an Autodesk Educational Product" appears on all four sides of the page. Can these be removed or at least limited to one side of the page only? It spoils every drawing and my one solution is to trim each side -not ideal! Maybe alter the margins?
Cannot get rid of it, sorry. :)
and your drawing is tainted with the student stamp
The stamp is there so that drawings produced with the student version cannot be used for commercial purposes. It cannot be removed. I'm sure your instructor doesn't mind that the stamp is on your drawings.
See here for further discussion of the educational plot stamp: http://www.cadtutor.net/forum/showthread.php?t=39060
Thanks for the prompt replies -I might just trim them off!
Are you submitting the drawings as part of your class?
No, the college has a fully licenced product, I assume, and the drawings print out as seen. My student version is for home projects and I just found it annoying that the text was on each margin .
Home projects? Personal use then and not commercial use?
Search the forum. There is a recent discussion regarding removing the educational plot stamp. However, pay close attention to what the OP is going through. There is a price to be paid for using the student version for commercial purposes. It's your call.
As I said in my previous post I`m using it for home projects ( model engineering ) and my course work revision.I`m currently unemployed and do not use the software in any commercial form.
Circumvent the educational stamp at your own risk. Should it come back later to bite you in the backside you have no one but yourself to blame.
This topic is now closed to further replies.
