I searched but didn't find anything.
I have a drawing with several different dimension styles that have the alternate units turned on and the are displayed in Millimeters, now the Architect would like them Displayed in Meters.
I can't figure out how to change the dimension style with the corrected info. I have to update about 100 drawings with at least 3 dim styles in each drawing. I know I can change it using Dimstyle, but I'd rather automate the process if I can.
I need to modify the existing dimstyle without using dim overrides.
thanks for your help.
Try this mate:
(defun c:alt (/ doc)
 (vl-load-com)
 (vlax-for dim (vla-get-Dimstyles
                 (setq doc
                   (vla-get-ActiveDocument
                     (vlax-get-acad-object))))
   (vla-put-activeDimstyle doc dim)
   (setvar "DIMALTF" 0.001)
   (vla-copyfrom dim doc))
 (princ))
not sure how to setup this one? loaded it, typed alt but didn't see it do anything.
Check your dim styles.
I see it created a few new ones,
What I'm looking to do is modify the existing ones to new settings, without having to do each one individually.
It shouldn't have created anything :huh:
sorry, that was from the other lisp, before filling in my layers. :oops:
what is it suppose to do?
I like that Lee. It changed the Alt Units Multiplier. Thats great.
Its supposed to do what you requested it to do... :wink:
Changes the Alternative Units Multiplier to 0.001 to convert mm to m.
Lee,
I would assume that only will apply to the current dimstyle?
I just found out its changing in all dimstyles current or not, Not sure if thats a good idea.
Well, that is what was requested. :wink:
Ok, But if you were using a drawing with multiple viewports with different scales, You might not want to change all of them.
Just a thought.
what I have to change in the dimstyle is the following
Multiplier for alt untis: 25.4 to .02540
Suffix: from MM to M
this sets the dimstyle to display correctly once I save it.
is there a way to just change those on specific dim styles?
yes, but none of this was specified in the OP... :unsure:
sorry I wasn't very clear in my OP, I can see that it would work, but it seems I would have to manually update the dims, as they don't automatically update when the change is made.
Try to explain the whole problem next time, but this should sort you:
(defun c:alt (/ dimlst doc ss)
 (vl-load-com)
 (setq dimlst '("DIM_STYL1" "DIM_STYL2")) ;; Change as necessary
                 (setq doc
   (if (vl-position (vla-get-Name dim) dimlst)
       (setvar "DIMALTF" 0.02540)
       (setvar "DIMAPOST" "M")
       (vla-copyfrom dim doc))))
 (if (setq ss (ssget "_X" '((0 . "DIMENSION"))))
   (mapcar 'vla-update
     (mapcar 'vlax-ename->vla-object
       (mapcar 'cadr (ssnamex ss)))))
 (princ))
Update list as necessary.
sometimes trying to figure out these lisp things I really feel like the computer it really taking to me. lamo.gif
but once I get them working, usually with others help it sure is nice. biggrin.gif
