See if this helps :)
(defun getobjlayoutname    (obj /)
 (cond    ((= (type obj) 'ename) (cdr (assoc 410 (entget obj))))
   ((= (type obj) 'vla-object) (cdr (assoc 410 (entget (vlax-vla-object->ename obj)))))
(setq layname (getobjlayoutname (car (entsel))))
(setq layobj (vla-item (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))layname))
  • Replies 36
  • Lee Mac
    16
  • SteveK
    16
  • ronjonp
    3
  • Patrick_35
    2
Hey Ron, thanks. That's a good work-a-round, I'll use it. And I did not know about the type function; that's helpful.
It's strange get-layout doesn't work though it turns up blue in the vlisp editor don't you think?
Another method:
(defun getlayout (Obj)
 (vla-get-Name
   (vla-get-layout
     (vla-objectidtoobject
       (vla-get-ActiveDocument
           (vla-get-ownerid Obj)))))
Not really. Objects don't have the layout property.
Check the propertys of an object using vlax-dump-object :)
Thanks Lee. That's a good way of staying with a vla-object.
Yeah but that's whats strange. vla-objects seem to carry lots more information than entities yet it doesn't carry the layout it's on whereas entities do.
That said your method does include vla-get-layout which indicates it is stored somewhere and vlax-dump-object is more just "surface" information...?
When objects are drawn they are defined within a block - whether that be the ModelSpace/PaperSpace blocks, or definition within an AutoCAD block definition. (I think we've already had a convo about these blocks), and so, the owner of the object is the block in which it is defined. So I have retrieved the owner id, converted it back to a VLA-Object (block), which has the layout property.
Lee
Thanks for explaining mate. Sorry you have to explain things so many times. When it's the same problem from a different angle sometimes it's hard to see that it's the same answer.:unsure:
No worries, I am happy to explain - just tying all the knowledge together :)
  Lee Mac said:
Another method:
 (vla-get-Name
   (vla-get-layout
Nice....... :) (the dots are for the 10 character limit):lol:
Thanks Ron :D
  • 4 weeks later...
Hey guys,
Just another quick question relating to layouts; how do I get the paperspace object if I have the layout/tab name?
Two ways:
Either using the vla-item function within a function to catch exceptions:
(defun get_item (i col / item)
 (if (not (vl-catch-all-error-p
            (setq item
              (vl-catch-all-apply 'vla-item
                (list col i)))))
   item))
(defun c:test ( )
 (get_item "Layout1" (vla-get-layouts
                         (vlax-get-acad-object)))))
Or, just by cycling through the collection itself:
(defun c:test (/ result)
 (vlax-for lay (vla-get-layouts
                 (vla-get-activeDocument
   (if (eq "Layout1" (vla-get-Name lay))
     (setq result lay)))
 result)
Lee,
I'm having some trouble using it.
For my current task, I want to insert a block on a specified layout. This I currently do by finding an object on the specified layout and getting the paperspace object (code you helped me with somewhere else):
(setq [color=Blue][b]pspc[/b][/color] (vla-objectidtoobject (vla-get-activedocument
                    (vla-get-ownerid <object on Layout1>)))
(setq blk (vla-insertblock [color=Blue][b]pspc[/b][/color]
              (vlax-3d-point '(0.0 0.0 0.0))
              "New Block"
              1
              1
              1
              0
I was hoping to substitute the pspc variable with what you've given me:
; Get Layout Paperspace Object
 (defun layoutObj (layName / result)
     (if (eq layName (vla-get-Name lay))
   (setq result lay)))
   result)
(setq [b][color=Blue]pspc[/color][/b] (layoutObj "Layout1"))
              "New Block"
              1
              1
              1
              0
But this doesn't work.
Is there another step to get it as a paperspace object?
Try this instead: (setq pspc (vla-get-block (layoutobj "Layout1")))
Thanks Ron that did it! :)
(You wouldn't think it would reading the helpfile on vla-get-block though - Specifies block of MLeaderStyle? :?)
