Lee,
thank you again, a perfect explanation!
regards
Wolfgang
  • Replies 31
  • Lee Mac
    14
  • wkplan
    9
  • ollie
    4
  • Rooster
    3
Hi all,
i thought it would be a good idea to choose at program-start, which type of LWPoly is checked.
Because this is determined mainly in the part of the ssget-function with
  (if (setq ss (ssget "_X" (list '(0 . "LWPOLYLINE")
                               (cons 8 (getvar "CLAYER")) '(70 . 1))))
, wherein (70 . 1) means a closed polyline and (70 . 0) means an open polyline, i believed this could be easy done:
- define a new variable (here "flag")
- let the user make a choice
- parse this variable to the (70 . x)-part of the code
Thought that parsing this variable should work exact as the way the current layer is defined in the selection-set, but there is no luck to me.
Here is what i have so far:
; Check for open polylines
; (c) 2009 Lee Mac
(defun c:GetLwClsd (/ ss lay flag)
   (initget 1 "0 1") ; only accept these values as user-input
       (setq flag (getkword "\nLooking for open < 0 > or closed < 1 > LW-Polylines?")); define a variable and let user fill it
   (princ flag) ; just for information, not really needed
;  (if (setq ss (ssget "_X" (list '(0 . "LWPOLYLINE")
;                                 (cons 8 (getvar "CLAYER")) '(70 . 1)))) ; original part of the code
 [color=Blue](if (setq ss (ssget "_X" (list '(0 . "LWPOLYLINE") (cons 8 (getvar "CLAYER")) '(cons 70 (getvar "flag")))))[/color]; and here it fails
     (foreach ent (mapcar 'cadr (ssnamex ss))
       (setq lay (tblsearch "LAYER"
                   (cdr (assoc 8 (entget ent)))))
       (if (or (eq 1 (logand 1 (cdr (assoc 70 lay))))
               (eq 4 (logand 4 (cdr (assoc 70 lay)))))
         (ssdel ent ss)))
     (princ (strcat "\n" (itoa (sslength ss)) " found."))
     (sssetfirst nil ss))
   (princ "\n<< nothing found >>"))
 (princ))
(textscr); bring text-window to front and inform user
(princ "\nSearching LW-Polylines at curent layer. Note: splines, curved fit, and 3D plines will not work\nStart with mit << GetLwClsd >>")
Everytime i run it, I can choose the value for "flag" and then it fails.
Where I'm going wrong?
Wolfgang
Take a look at the comments on this code Wolfgang, hopefully it will explain things a bit:
 [i][color=#990099];[/color][/i]
 [i][color=#990099]; Check for open polylines[/color][/i]
 [i][color=#990099]; (c) 2009 Lee Mac    [/color][/i]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:GetLwClsd  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss[b][color=RED])[/color][/b] [i][color=#990099]; Notice that *flag_def* is not localised, as it is a global variable[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] *flag_def* [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] *flag_def* [b][color=#ff00ff]"Open"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099];; Set first-time default[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#ff00ff]"Open Closed"[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Only allow these values, allow enter also[/color][/i]
   [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]getkword[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nLooking for [O]pen or [C]losed LWPolylines? <"[/color][/b] *flag_def* [b][color=#ff00ff]"> : "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [i][color=#990099];; Either a keyword has been entered, hence set it as the new default[/color][/i]
         [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] *flag_def*[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099];; Else use the original default[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss
       [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"LWPOLYLINE"[/color][/b][b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]8[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"CLAYER"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]70[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] *flag_def* [b][color=#ff00ff]"Open"[/color][/b][b][color=RED])[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                               [i][color=#990099];; If *flag_def* is "Open" use 0, else use 1.[/color][/i]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] ent  [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lay [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"LAYER"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]8[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]logand[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]70[/color][/b] lay[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]4[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]logand[/color][/b] [b][color=#009900]4[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]70[/color][/b] lay[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]ssdel[/color][/b] ent ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\n"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]itoa[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]sslength[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=#ff00ff]" found."[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]sssetfirst[/color][/b] [b][color=BLUE]nil[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<< nothing found >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]textscr[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; bring text-window to front and inform user[/color][/i]
[b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\nSearching LW-Polylines at curent layer.
         will not work\nStart with mit << GetLwClsd >>"[/color][/b][b][color=RED])[/color][/b]
Lee,
this is perfect!
Thankyou.
I have to read carefull youre code, but with these excellent comments :)
Didn't know the initget-function, but now i should be able to use this in similiar cases.
Still far away from writing my own code, just tweek stolen code a little bit.
Regards
Wolfgang
  wkplan said:
this is perfect!
Thankyou.
Not a problem Wolfgang, happy to help.
The Initget is a useful function, not only for getkword but for all the "getXXX" functions and"entsel" also. Read up on the bit arguments for more.
Don't worry, you can learn a lot from other peoples code, and its only practice after all. :)
If you have any further questions, just ask.
Regards,
Lee
Hello Lee,
at the first look anythings is great.
I tested the routine with a larger drawing, which contains ~300 polylines, all of them are closed. (Checked in property window and hatched them, all is fine. But the drawing was done by different people).
GetLwClsd failed in correct count, I wondered why.
Reading the documentation, I noticed that the groupcode 70 can hold three bits (for LWPolylines only, Polylines are more complex):
0 = polyline is open (default)
1 = polyline is closed
128 = plinegen is used
This means, there are 4 combinations possible:
0 = open polyline, plinegen not used
1 = closed polyline, plinegen not used
128 = open polyline, plinegen is used
129 = closed polyline, plinegen is used
Looked some closer at the not counted polylines, I noticed they are different: property "use linetype" is activated :o, and there's the reason, because plinegen leads straight to this property.
How will a filter-statement look, that checks for:
a) ( 70 . 0 ) or ( 70 . 128 ) if I will look for open polylines, and
b) ( 70 . 1 ) or ( 70 . 129 ) if I will count closed polylines?
Another method would be some kind of brute force, just collect all polylines and change the groupcode, but this looks to me a little destructive.
regards
Wolfgang
How about this:
               [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]-4[/color][/b] [b][color=#ff00ff]"<OR"[/color][/b][b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]70[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] *flag_def* [b][color=#ff00ff]"Open"[/color][/b][b][color=RED])[/color][/b] [b][color=#009900]128[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] [b][color=#009900]129[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]-4[/color][/b] [b][color=#ff00ff]"OR>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Lee,
thanks again!
What started as some kind of interessting stuff, leaded now to a verry usefull function, which I believe other people will find it usefull too.
I learned a lot, maybee more in one day reading youre excellent postings, than reading 14 days lisp-documentation.
(I knew, there is plenty of good lisp-docu around, and I have to read as many as I can...)
Kind regards
Wolfgang
I'm glad I could help out.
Documentation is good, but there is no-one that you can ask if you get stuck - thats what I like about the forums :)
Lee
  • 7 years later...
Hi LeeMac,
i found this post in google. i need small extension in your great code. i need close all poly lines in my drawing and any layer poly lines automatically. is this possible?
Thanks.
