INTERNAL ERROR
Guest RODDY1
Guest RODDY1
GOOD MORNING
CAN ANYONE HELP,
I SAVED MY DRAWING FILE LAST NIGHT (AutcCad2004) AND
THIS MORNING WHEN TRYING TO OPEN IT, THE ERROR READS:
INTERNAL ERROR:
!dbqspace.h@410:
eOutOfRange
:cry:
SO I TRIED TO RECOVER, BUT DOES NOT WORK
SO I TRIED OPENING .BAK FILE (SAME PROBLEM)
HAS ANYONE COME ACROSS THIS ERROR ?
I CANNOT AFFORD TO LOSE A FULL DAYS WORK ON THIS PROJECT
ANY HELP WOULD BE APPREICATED
Morning Roddy. Do you have another PC/AutoCAD to try to open the same drawing? If so, you can determine if it is the drawing that's at fault or if it's a problem specific to your PC.
Guest RODDY1
Just tired opening drawing on another pc on network, it generates the drawing on screen the same as mine , up to the same point before the
error message appears. the drawing is a conveyor system drawn in
3D Models, is there any website specifically for error messages.
Guest RODDY1
Tried both your ideas.
Command: _insert
* Invalid *
Partial Open Layer 0
Unable to open this drawing
it contains incorrect or corrupted information
Tried partial opening .bak file
the following appears:
INTERNAL ERROR:
!saveas.cpp@440:
eGeneralModelingFailure
The file memory size seems ok 28,699 kb so i dont think
any information as been lost.
Anyway thanks for your help.
Is there any services on the web for uncorrupting drawing files
i will search.
Thanks Again
Guest RODDY1
Ran out of ideas on this problem.
I have tried opening the drawing file using AutoCad2006
(didn't work)
I have tried opening the file using a trial version of Intellicad
(didn't work)
Could i email the drawing to one of the members who
would have alot more knowledge than me ?
thanks
and sorry to be a pain
  • 4 years later...
Ah crap. Same thing's just happened to me. Tried everything. This thread is 4 and a half years old. Any progress since then?
DO NOT WANT TO REDRAW ENTIRE BLOODY THING.
Hi autocadians,
I have just had a similar problem, caused by a power failure mid session, Autocad 2007, Drawing file not valid, tried the DXF, then a message saying File internal error. the partial open option goes off when click on this file, yet I can see it in the preview. Does anyone know any way to access it, thanks
Alexim
Hey ReMark.
Ok, I tried recovering the drawing, but when I tried to open the recovered file, it just said "drawing is not valid". I also noticed that the size of said recover file was 0kb.
Tried renaming the .bak file, it actually loaded a little more than the corrupted file itself, but then I got a similar error message (but instead of "out of range" it said "permanently deleted".
I downloaded a batch converter to try and pull it back to R14 (I heard that works sometimes), but the converter gives me an error saying "Error opening file: CRC doesn't match". I tried it with a non-corrupted file; it works fine.
Then in desperation I tried downloading a data recovery program in order to access older .bak files (not sure if it even works like that), but that proved fruitless as this file is on my company server, and the recovery program would only recognize my C drive (though it had an option to scan "Unmounted volumes").
And then I gives up.
:cry:
RnR Draughtsman:
You're entirely welcomed. All I did was pass along some information though. I'm sure you would have found it on your own at some point.
BTW...don't let my wife hear you say that.:lol:
