ABGroup Posted May 9, 2008 Posted May 9, 2008 Within AutoCAD LT 2008, I have two drawings open. I can click on an entity and right-click copy, with no problem. When I activate the other drawing and right-click paste, it may take up to 5 minutes before the entity is pasted. The entity can be as simple as a single line. The machine is a new dual-core machine with 3G of ram. I believe it may be an issue with the drawing, however I have gone through the process of cleaning and purging, but still no luck. Please help. Kind regards, Harley Quote
LCE Posted May 9, 2008 Posted May 9, 2008 OK, and what are the results if you start 2 new drawings, draw and line in 1 then cut and paste it to the other? Quote
ReMark Posted May 9, 2008 Posted May 9, 2008 Does the drawing have a number of X-refs attached? Quote
Opc 12 Posted May 23, 2008 Posted May 23, 2008 I had a similar problem, my pc was to slow and i didn't have enough ram. That could be your prob. By the way how big is the copied section if it is rather large then that might be your prob. Try take a smaller piece to a new drawing. Quote
ABGroup Posted May 23, 2008 Author Posted May 23, 2008 The two drawings could be empty apart for a single line and the same problem would happen. Quote
ReMark Posted May 23, 2008 Posted May 23, 2008 Please take a look at similar threads by using the Search option above. As your search criteria use the phrase "cut & paste". If you don't find a solution among the available responses that works for you please post back and we'll put our collective heads together and see if we can help solve your problem. Works for you? Quote
Ishea Posted June 4, 2008 Posted June 4, 2008 I was wondering has anyone had any success in finding out why some drawings were hanging when cut/pasting- I have similar problems because I do tend to do a lot of cut and pasting from various drawings etc. I have noticed that even if I purge the drawing - my drawings are slower to cut/paste in than another drawing using the same template, this is after I have cut/paste larger drawings or sections into it. The file size has only slightly increased from the main template, and I may have even deleted the items I pasted in as I only used them temporarily. I have tried different machines with high specs and loads of ram. I have also cleared out the PC's cut/paste clipboard and even purged all temp files. It "appears" the cad file still contains some hidden information??? Has anyone else come across this – I have only noticed this occurring in version 2008 Quote
ReMark Posted June 4, 2008 Posted June 4, 2008 Check this out. Note that at the bottom there is a reference to 2008. http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=10031804&linkID=9240617 Quote
Cooter Posted November 12, 2009 Posted November 12, 2009 The link is invalid!!! How did you fix it??? Quote
ReMark Posted November 13, 2009 Posted November 13, 2009 The link is invalid!!! How did you fix it??? Cooter: It is not uncommon for this to happen (link invalid). The post was made over a year ago and AutoDesk likes to rearrange things from time to time. Are you current with the last service pack available for 2008? Have you tried a search of the AutoDesk website? Quote
cadviser Posted January 26, 2010 Posted January 26, 2010 how to fix copy and paste problem type in -scalelistedit at command prompt type in R type in yes type in esc to return command prompt ..drawings will reduce to a smaller size...xrefs seem to add more sscales to the list ..the more xrefs the more scales... must be done for every drawing ..(not every layout) Quote
ReMark Posted January 26, 2010 Posted January 26, 2010 I guess it ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ bears repeating? OK kids, don't make me have to tell you again! LOL Quote
shahik Posted May 22, 2012 Posted May 22, 2012 I have the same problem but i could not find the answer , the link was broken Quote
SLW210 Posted May 22, 2012 Posted May 22, 2012 I have the same problem but i could not find the answer , the link was broken See post #14 about editing the scale list. Make sure you have all Updates & Service Packs. Quote
shahik Posted May 23, 2012 Posted May 23, 2012 Thanks a lot , it is working and I can copy and paste inside a drawing and between drawings with peace of mind. I am very grateful Shahik Quote
shahik Posted March 1, 2014 Posted March 1, 2014 Hi again, I am getting again the same problem , Unfortunately I missed the file that I downloaded last time ,can you be kind and send me the file or the link to download it once again? My Auto cad LT 2008 has all available updates . I am saying my heartily thanks in advance. Shahik Quote
ReMark Posted March 1, 2014 Posted March 1, 2014 CADTutor does not send files on request. Have you downloaded and installed all updates and hotfixes for AutoCAD 2008? Have you followed the instructions for editing the scalelist manually as outlined in post #14? Quote
