YuanMasipag Posted July 23, 2009 Posted July 23, 2009 i need help... how do i draw a lot plan using the orientations of the bearings given, say, south 51-17 west, 212.06 meters... any1 teach me... i'm a beginner... thanx:) Quote
lpseifert Posted July 23, 2009 Posted July 23, 2009 http://www.cadtutor.net/tutorials/autocad/survey-data.php Quote
YuanMasipag Posted July 24, 2009 Author Posted July 24, 2009 thanx carl, now i know... BIG help:D Quote
kevness Posted May 18, 2017 Posted May 18, 2017 Hi i got a plot plan to redraw in autocad, but something looks off with the bearings. I know bearing usually looks like this S30D57'08"E but the bearings on the plan looks like this N19d36'47" there is not direction at the end of it. Quote
ReMark Posted May 18, 2017 Posted May 18, 2017 kevness: Please refrain from double posting as it only leads to confusion. Thank you. Quote
CyberAngel Posted May 18, 2017 Posted May 18, 2017 Unless the line is very close to vertical, you can usually tell which way it leans. One solution is to scan the plat and xref it temporarily. Once you have it scaled correctly, you can check your bearings and distances against it. And whoever you got that plat from, tell them to go back to surveyor's school . Quote
