happyunited Posted July 20, 2009 Posted July 20, 2009 Please find attached drawing. On that dimension on the attached drawing how do I; 1) Rotate the text horz. without putting 0.001 in the rotation box? 2) After it's rotated how to I justify the text to the left as it only seems to let me justify in the middle. Many thanks in advance. Drawing4.dwgFetching info... Quote
Eatonpcat Posted July 20, 2009 Posted July 20, 2009 Dimension... Align text...Home Then text outside align...off This will rotate text horiz. You can change just. with text editor Quote
happyunited Posted July 21, 2009 Author Posted July 21, 2009 Thank you both for your relpy. Not just the justify issue, how do I change that? Quote
Eatonpcat Posted July 21, 2009 Posted July 21, 2009 StevSmith, I thought he just wanted to modify one dimension, but if he wants all dimensions changed then changing the dimstyle is best. Quote
happyunited Posted July 21, 2009 Author Posted July 21, 2009 Eatonpcat said: Dimension... Align text...Home Then text outside align...off This will rotate text horiz. You can change just. with text editor I did just want to change just one dimension but both answers are very useful. How do I do what you said?? Quote
Eatonpcat Posted July 21, 2009 Posted July 21, 2009 The attachment is the dimension revised to your specs. Drawing4[1].dwgFetching info... Quote
stevsmith Posted July 21, 2009 Posted July 21, 2009 Sorry, I must have interpretated it incorrectly. Quote
