CADMASTER1128 Posted July 20, 2009 Posted July 20, 2009 What is everybody's favorite year/ edition of AutoCAD. My personal favorite is Auto Architecture 2008. The reason I like this one so much is because it has all the features I like but runs faster and smoother than 2009 and 2010. However I like the UI of 2010. By the end of 2009, I am guessing that 2010 Architecture will become my new favorite! Quote
michaeloureiro Posted July 20, 2009 Posted July 20, 2009 2007, haven´t tried 2008 yet and don´t want to try 2009 or 10 Quote
CADMASTER1128 Posted July 20, 2009 Author Posted July 20, 2009 2007, haven´t tried 2008 yet and don´t want to try 2009 or 10 Why not 09 or 10? Quote
CADMASTER1128 Posted July 20, 2009 Author Posted July 20, 2009 What do you like so much about 9 or 12? Quote
michaeloureiro Posted July 20, 2009 Posted July 20, 2009 Why not 09 or 10? scared of the ribbon! Quote
CADMASTER1128 Posted July 20, 2009 Author Posted July 20, 2009 scared of the ribbon! See and I like the ribbon. Quote
ReMark Posted July 20, 2009 Posted July 20, 2009 2007. That's when AD really started to flesh out 3D. Quote
Coosbaylumber Posted July 20, 2009 Posted July 20, 2009 version 9 or 12 DOS rules! Most of my work is done using lines and text. I really have no reason to upgrade to a newer version. Only omission right now is the ability to import TIF type pictures (seldom a need each year), older text fonts (the standard TXT format is only one to interchange back and forth) and late model plotters (for drivers today are quite OS oriented). Far as I see, all the old type written commands work good in newer versions. Wm. Quote
ReMark Posted July 20, 2009 Posted July 20, 2009 Release 9 was probably the best of the DOS versions. Quote
Tankman Posted July 20, 2009 Posted July 20, 2009 I have both '05 and '07. Use 2005 mostly anymore, it's loaded on my laptop. Lately, past year or two, I find myself working from my laptop, anywhere I want to be. All my work is simple 2D, plumbing plan views and elevation views. Quote
Coosbaylumber Posted July 20, 2009 Posted July 20, 2009 Release 9 was probably the best of the DOS versions. I used Release 9 back when. I think it had zero ability to recognise XREFs and Paper space through. Was told when upgrading from verion 8 it had, but wasn't there after it got loaded on. Wm. Quote
Ritch7 Posted July 20, 2009 Posted July 20, 2009 Iv'e been using MEP 2010 recently for about 2 months now I like it, It all just depends on what extra tools and applications you need to use often to do the job that your'e working on. Quote
dumfatnhappy Posted July 20, 2009 Posted July 20, 2009 Iv'e been using MEP 2010 recently for about 2 months now I like it, It all just depends on what extra tools and applications you need to use often to do the job that your'e working on. in an attempt not to hijack this thread I've created a new one in MEP. Would you mind responing to it (diff. between 2009 & 2010) thanks Quote
CADMASTER1128 Posted July 20, 2009 Author Posted July 20, 2009 Reading all these post, I find it amazing how many different favorite versions of AutoCAD there are! Quote
f700es Posted July 20, 2009 Posted July 20, 2009 2008 is my favorite. Classic UI but with the Dashboard. Quote
stevsmith Posted July 20, 2009 Posted July 20, 2009 Vanilla 2008 I feel was the best for 3d. Autodesk started to go a bit nuts with the ribbon in 09. Trying to figure out what everyone uses typically. THEN WHAT DO THEY DO!!!! Change it all over again in 2010. Make up your feckin minds!! Quote
Lee Mac Posted July 20, 2009 Posted July 20, 2009 2004 was my favourite for ages and ages, 'cause you knew where you stood with it. But I've got to say, 2010 is growing on me Quote
