I am wondering if anyone could help here. I was looking thru the Developer Help Section in AutoCAD's help documentation and came across Visual Lisp Functions that start with the prefixes:
vl
vlax
vlr
However there does not seem to be many. I have also seen some functions start with (vla) that are not listed at all. This seems to be confusing to me.
Where do you get all these functions from?
Is there an index where they can be found?
I am sure these functions are not randomly made up and should be a complete listing somewhere.
Any clarification would be very helpful.
  • Replies 33
  • The Buzzard
    15
  • Lee Mac
    11
  • rkmcswain
    3
  • Se7en
    2
Posted Images
They are all documented in the Developers Guide (\Help\acad_dev.chm), more specifically, the "AutoCAD ActiveX and VBA Reference"
Thank you, I will check that out. I was under the impression that it was for VBA only.
The Visual LISP Editor Help files are written with VBA in mind, so you may have to make a few "links" between the two.
for example:
Type this in the VLIDE:
vla-get-layer
You will see it turn blue.
Double click on it so that the whole function is selected, then click on the help button.
You will see a page detailing the "layer" property, giving information on arguments and returns of this property.
In the contents page of the VLIDE, have a look at the Active X and VBA Reference - there you will see a list of all the properties and methods available to you :)
Lee
for example:
vla-get-layer
[ATTACH]13249[/ATTACH]
Lee
Lee,
This Visual Lisp seems like a guessing game. The resources available are very confusing to know what is what.
Lee,
You need to experiment with it a bit I find, yes.
From what I can tell
vlax- = Object level
vlr - = Event
vla - = Methods & Properties of objects
Open the vbaide with this an mind and go wild for a bit
I may be wron right enough
Ollie
vlr - = Event
Ollie
Thank You ollie,
That is very helpful.
vlax-curve functions are really good to look into... takes all the messiness out of DXF tables with objects.
I wrote up something on the differences once. I will have to look around for that. I cant promise anything though; that article would be 5 or 6 hard drives and several years ago.
Thanks Lee,
It is at this point a bit beyond me though. I still cannot make heads or tails out of the VBA section and how this relates to VL. It seems all trial and error to me at this point, But maybe I am trying to get to far ahead of myself.
Patience I guess
Thanks Se7en,
I appreciate anything that can clear up some of the mystery behind VL.
The Curve functions are well documented, and will also work with Entity Names, as well as VLA-Objects - definitely worth a look.
just search for vlax-curve-, in the help files. :)
EDIT:
A great overview is the Section "Curve Measurement Functions" in the Developers Guide.
EDIT:
I will give it a look, But I have had no sucess finding VL functions except for those listed in the AutoLISP Reference for AutoLisp Functions. My resouces for VL seems very limited.
All the necessary functions are listed.
For example, to change a property of an object, you can use:
([color=Blue][b]vlax-put-property[/b] [/color][color=Red][i]obj [/i][i]property[/i][i] arg[/i][/color])
Which is documented, and has the same functionality as:
([color=Blue][b]vla-put-[color=Red]<property>[/color][/b][/color] [color=Red][i]obj property arg[/i][/color])
As an example:
[b]Obj is a Circle VLA-Object[/b]
[color=Blue][b]
(vla-put-layer Obj "0")[/b][/color]
is the same as:
[b][color=Blue]
(vlax-put-property Obj 'Layer "0")[/color][/b]
The same with the methods:
([color=Blue][b]vlax-invoke-method[/b][/color] [i][color=Red][i]obj [/i][i]method[/i][i] arg [arg...][/i][/color][/i])
And
([color=Blue][b]vla-[/b][/color][color=Red][b]<method>[/b][/color] [color=Red][i]Obj arg [arg...][/i][/color])
Are the same, or even just
([color=Blue][b]vlax-invoke[/b][/color][color=Red][i] Obj arg [arg...][/i][/color])
Although the above has the same functionality, it will return data in AutoLISP data types, as opposed to VLA data types such as Variants and Safearrays.
If I have missed something, anyone feel free to chime in :)
Lee
Part of what you have shown me is my point. How am I suppose to know this if I do not understand the difference between VL, VLA, VLAX & so on and so forth. I am not sure where or how each is used, But maybe I have not reach that point yet in learning this. Maybe I am learning backwards. Not sure.
I have seen other prefixes used that are not shown in the help section at all. A very dry type read Im afraid.
If I were to read the entire help section for VL, I would still draw blanks on these issues since I cannot find the resources that I need to help understand this stuff.
Everyone has their own methods of learning. I prefer to test functions to see what they do and draw on my own conclusions.
All I am saying is that there is not much that you cannot do just using the functions documented in the help files. :)
EDIT:
Forgot to mention, so see a list of functions available, use the Apropos in the VLIDE -
for example: type "vl" and hit Ctrl-Shift-Space :)
I realize that. But they help to get a better understanding. To learn regular lisp each function is documented and has examples for their usage with the expected type of return values you would encounter.
And its nicely arranged.
Visual Lisp on the other hand is like doing a cross-word puzzle with a blind fold on with the help section thats available.
Also, take note of the edited post above - that apropos window is handy.
