Is There Any Way To Insert Block At Intersection Points In Selected Part Or In Whole Drawing If Not
Yes, when you select what you've wanted to insert, you'll get a box which will ask wether u want to specify on screen of select the co-ordinates in the box. You can also do this by typing the co-ordinates on screen by typing 0,0,0 for example. Note that u can also scale up with the insert box, this will do it from the point you specify.
I DON'T MEAN THAT I WILL EXPLAIN MORE FOR ATTACHED FILE I NEED INSERT BLOCK AT SOME OR ALL INTERSECTION POINTS ONCE
1.dwg
As far as im aware you cant insert a block at multiple insertion points, it would be best to bring one in a the point, either specifed on screen or with your mouse and the copy with your selected base point and move them about the drawing accordingly.
CAPS LOCK IS CRUISE CONTROL FOR COOL! :D
