fuccaro Posted July 20, 2009 Posted July 20, 2009 We have a computer with AutoCAD 2004. The IT guy installed a new menu called Hasco. But now the menu bar contains only the Hasco and the Express menus. He is unable to fix the problem. I try to help but these days, using the CUI I forgot how to do such "old" things. Can anyone post a quick solution please? Thanks! Quote
The Buzzard Posted July 20, 2009 Posted July 20, 2009 1. At the command prompt type menuload and the Menu Customization dialog will appear. 2. Browse for the acad.mnc file under the Menu Groups tab. C:\Documents and Settings\Your Profile\Application Data\Autodesk\AutoCAD 2004\R16.0\enu\Support\acad.mnc 3. When the menu ACAD appears in the File Name Box, Click Load. After the menu is loaded it will appear in the Menu Groups list box. 4. Click the Menu Bar tab and in the Menu Group popup list select ACAD. 5. The menus will now appear under Menus, Click the Insert button to insert each of the drop down menus under ACAD you wish. See images below: Quote
fuccaro Posted July 30, 2009 Author Posted July 30, 2009 Sorry for the late answer! Thank you for your time, we will try it right now. Quote
