VisDak Posted July 19, 2009 Posted July 19, 2009 Hi to all, Good Day, I have some old Lisp route the will shade on round plan or symbol by a ramp up on plan, kindly see the image: (defun c:shd ()(setq old_error *error* *error* ai_error) (setq cecho (getvar "cmdecho")) (setvar "cmdecho" 0)(command "_.UNDO" "_GROUP") (initget (+ 1 2 )(setq fpt (getpoint "\nStarting Point of Shade ? ")) (initget (+ 1 2 )(setq spt (getpoint "\nEnd Point of Line Shade ? " fpt)) (initget (+ 1 2 )(setq opt (getpoint "\nDirection of Line Shade ? " fpt)) (setq dis (abs (distance fpt opt)))(setq hmany 1000) (command "line" fpt spt "")(setq flc (entlast)) (setq coeff (/ dis 1000))(repeat hmany (if (< (* coeff 1.25) dis)(progn (setq coeff (* coeff 1.25)) (command "offset" coeff flc opt "") (prompt (strcat "\rDRAWING IN PROGRESS, PLEASE WAIT... " (rtos (* (/ (float (* coeff 1.24))(float dis))100.000) 2 0)" %")) ))) (command "_.UNDO" "_E")(setvar "cmdecho" cecho)(princ)) the image "1" represent the route that i have, on image "2" is the one i need to be revised by it means, i like to be have this route "image 2" that i will use on circular to rectangular connection symbol it will be perfect on gredient deviding a line, please help me if you have some additional/revised to this route, thanks to all Quote
Lee Mac Posted July 19, 2009 Posted July 19, 2009 Like this: (defun c:shd (/ old_error *error* cecho fpt spt opt dis ang hmany flc) (setq old_error *error* *error* ai_error) (setq cecho (getvar "cmdecho")) (setvar "cmdecho" 0) (command "_.UNDO" "_GROUP") (initget (+ 1 2 ) (setq fpt (getpoint "\nStarting Point of Shade ? ")) (initget (+ 1 2 ) (setq spt (getpoint "\nEnd Point of Line Shade ? " fpt)) (initget (+ 1 2 ) (setq opt (getpoint "\nDirection of Line Shade ? " fpt)) (setq dis (abs (distance fpt opt))) (setq ang (angle fpt opt)) (setq hmany 1000) (command "line" fpt spt "") (setq flc (entlast)) (setq coeff (/ dis 1000.)) (repeat hmany (if (< (setq coeff (* coeff 1.25)) dis) (progn (command "_line" "_non" fpt "_non" (polar spt ang coeff) "") (princ (strcat "\rDRAWING IN PROGRESS, PLEASE WAIT... " (rtos (* (/ (* coeff 1.24) dis) 100.) 2 0) "%"))))) (command "_.UNDO" "_E") (setvar "cmdecho" cecho) (princ)) Quote
VisDak Posted July 19, 2009 Author Posted July 19, 2009 Wow, very fast, its perfect many thanks Lee Quote
