ollie Posted July 17, 2009 Posted July 17, 2009 Hi All (vla-get-visible c) ;Where c is a safearray list from an attblock The above line of code always returns true even when the attributes aren't visible Any thoughts community Cheers Ollie Quote
Lee Mac Posted July 17, 2009 Posted July 17, 2009 Objects themselves have the visibility property - which differs from the attribute type "invisible". You want to look at: vla-get-invisible Also, if c is a safearray list, then you will need to use the function on each member of the list [assuming you have used (safearray->list) ] Quote
ollie Posted July 17, 2009 Author Posted July 17, 2009 Objects themselves have the visibility property - which differs from the attribute type "invisible". You want to look at: vla-get-invisible Also, if c is a safearray list, then you will need to use the function on each member of the list [assuming you have used (safearray->list) ] Thanks Lee Similarly does anyone know the property name that contains the prompt string Cheers Ollie Quote
Lee Mac Posted July 17, 2009 Posted July 17, 2009 Thanks Lee Similarly does anyone know the property name that contains the prompt string Cheers Ollie See the other thread: http://www.cadtutor.net/forum/showthread.php?t=38364 Quote
