VisDak Posted July 16, 2009 Posted July 16, 2009 hi to all, Good Day, Please to help me to create a Lsp route that will automate selecting 2 individial levels of line by connecting a 45degree line/polyline and it will create a pipe offset. i just created the route that will insert a 45degree line block and endsel the block for exploding and fillet, (but much possible no need for insert a block) Kindly see attached image what look like to be, many Thanks, Quote
BIGAL Posted July 17, 2009 Posted July 17, 2009 You could certainly do in lisp but manually a quick way do the following Copy pick bottom line, base point is start point move to desired position along line Rotate Last Enter 135 enter angle is in degrees fillet pick 2 lines fillet pick 2 lines done Quote
Abdulellah Posted February 19, 2020 Posted February 19, 2020 This is .perfect for ......mr / beekee cz ( autodesk forum) angjoin.LSPFetching info... Quote
