Hi, I have an excel file which looks like this example:
x y length angle
208919.46 378003.48 0.0482 13.8851
I found out how to draw a line with this information. Add these columns in Excel.
line208919.46,378003.48@0.0482
then paste in the command line.
But what I really want is an arrow on the x,y which is scaled and angled accordingly.
I've tried substituting the line command with -insert c:\arrow.dwg but Cad needs an enter (space doesn't work) to continue.
How do you give a Cad enter in Excel ???
Any help would be greatly appreciated.
David.
Hi David,
You need to be in the VBA area with this kind of question- I'll ask a mod if they can move it for you...
Gary
ok, I wasn't sure where to put place my question
No problem- welcome to the forum! :)
You dont need to have a space. I would just do "saveas" on the excel document and save it as a text file (tab delimited) and have it be "filename.scr" then in autocad type "script" load the file and it should work like a champ.
A saveas in Excel doesn't work. But if I copy the cells to Wordpad and then do a saveas, then it works like a charm with a bit of tweaking. Only thing is, the file has roughly 5000 rows, so it takes about 15 min for the script to run.
Thanks for the help.
David.
thats odd. my excel has saveas...
David.
If you have a txt file with the information you quoted above, "x y length angle", then a simple LISP would make this task a 2 min procedure :thumbsup:
go the the cell below it,
eg
'A1' = stuff the before enter
'A2' = the things after enter can be done as much as possible
Of course one would have to know how to do this ??:oops:
I do have a Saveas in Excel, just not the option to save as a text (tab delimited).
not sure if something like this would work:
(defun c:txt2blk (/ file nl lst)
 (vl-load-com)
 (if (and (or (tblsearch "BLOCK" "arrow")
              (findfile "arrow.dwg"))
          (setq file
            (getfiled "Select Text File"
              (if *load *load "") "txt" ))
     (setq *load file file (open file "r"))
     (while (setq nl (read-line file))
       (setq lst (cons (StrBrk nl 9) lst)))
     (close file)
     (foreach x lst
       (command "_.-insert" "arrow" "_non"
         (mapcar 'distof (list (car x) (cadr x)))
           "1" "1" (distof (last x))))))
 (princ))
(defun StrBrk (str chrc / pos lst)
 (while (setq pos (vl-string-position chrc str))
   (setq lst (cons (substr str 1 pos) lst)
         str (substr str (+ pos 2))))
 (reverse (cons str lst)))
I have only taken into account the x,y and the angle as I am not of the orignal length of the arrow, to know how much to scale it by.
This assumes a text file with the data TAB delimited.
