Hi all,
Good day to all, I have a 3 Lisp that will automatically mulit-trimming lines according to wall intersection lines, :o
WALL-L.lsp: multi-trimming an angle line like fillet,
WALL-T.lsp: multi-trimming lines according to T connection
WALL-X.lsp: multi-trimming lines according to cross lines
I need to make this 3 routes to become 1 Lisp (3to1), by having a selections and then when the selection was choose and already select a lines want to trimmed, press enter button to go back on selection to choice another type trimmer, im trying to make this but always (error: malformed list on input) i attached my 3 lisp's to create by 1, Kindly please help me on this.:oops:
Many Thanks
WALL-L.LSP
WALL-T.LSP
WALL-X.LSP
Make a main defun to ask for selection and call the correct lisp/
Get rid of the C: part of all the other defuns so they can be called by the main defun
When the routine is finished just right click to re-enter it.
Main defun
This one has the C: so it can be called at the command line
Put this at the top of one of the files
(defun c:wallt ( / wtyp)
(initget "L T X)
(setq wtyp (getstring "Enter Trim Type: [L\T \X "))
(if (= wtyp “L”)(wall-l));_call correct lisp
(if (= wtyp “T”)(wall-t));_call correct lisp
(if (= wtyp “X”)(wall-x));_call correct lisp
);_defun
I have not checked this but you should get the idea.
I would make sure it works then compile to a VLX file just to make it easy to load
Thank JohnM,
i already tried to modified, no malfunction load no error:D only i dont understand why it continious to ta command system must be to select first the selection line, please have a check these i just attached the lisp route its to long because i just combined it sorry::oops:
Thanks again
wallt.lsp
Mate if i was you, i would use mlines, and all there joint features
How ever, i belive this is what you want?
edit
sorry visdak didnt see you create the solution
WALL-L.LSP
  • 11 months later...
flowerrobot, hi its good lisp but the wall X is not working.. thanks very much
  • 13 years later...
Fixed the X wall and also edited the prompt for the T so it's more explanatory. Like so:
WALL-L X fixed.LSP
