Hi, thank you, but there must be some mistake, because the script is not executed. It is may be in brackets or anythink else worse in it, but I don't undestand its syntax. Please look at it once more.
I replaced
                              (vlax-3D-point (trans '(0 0 1) 0 1)) 'row 'col)) nil
with
                              (vlax-3D-point (trans (getvar 'viewdir) 1 0 T)) 'row 'col)) nil
  • Replies 44
  • Lee Mac
    13
  • spasobn
    12
  • VAC
    7
  • m4rdy
    2
Posted Images
I overlooked the fact that the picked cell point has to be translated to the WCS:
(defun c:sCell (/ tab ent Obj pt tObj row col)
 (vl-load-com)
 (if (and (setq tab (car (entsel "\nSelect Table: ")))
          (eq "ACAD_TABLE" (cdr (assoc 0 (entget tab)))))
   (while
     (and
       (setq ent (car (entsel "\nSelect Room: ")))
       (vlax-property-available-p
         (setq Obj
           (vlax-ename->vla-object ent)) 'Area))
     (while
         (setq pt (getpoint "\nClick into Cell to place field: "))
         (cond ((vl-consp pt)
                (if (eq :vlax-true
                      (vla-hittest
                        (setq tObj
                          (vlax-ename->vla-object tab))
                            (vlax-3d-point (trans pt 1 0))
                              (vlax-3d-point (trans (getvar 'viewdir) 1 0 T)) 'row 'col)) nil
                  (princ "\n** No Cell Selected **")))
               (t (princ "\n** No Point Selected **")))))
     (vla-setText tObj row col
       (strcat
         "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid (vlax-ename->vla-object ent)) ">%).Area \\f \"%lu2%pr2%ds44%ct8[1e-006]\">%")))
   (princ "\n** No Table Selected **"))
 (princ))
  • 3 months later...
Hi, script works fine for me. I have one more question. I need to multiply the obtained area value by X, (for ex. 2times).
First, it shoud by set at the beginning of the script like
(setg multiplier 2)
 and how, to implement it to the script, I think it shoud be in this line?
       (strcat
or better
second way, script will ask me with the dialog at the begining of the script for variable "multiplier"
Thank you
First, it shoud by set at the beginning of the script like  "
(setg multiplier 2)
  how, to implement it I think to this line?
       (strcat
or better
Thank you
I find out answer to my both questions:
 (setq multiplier (getdist "\nSet multiplier")
and
"%<\\AcExpr (%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid (vlax-ename->vla-object ent)) ">%).Area>%*multiplier) \\f \"%lu2%pr2%ds44%ct8[1e-006]\">%")))
  • 1 year later...
Hi, LeeMac
On 7/9/2009 at 8:50 PM, Lee Mac said:
This will put your fields into cells in a table.
  • Select your table.
  • Select your rooms in turn.
  • Click inside the cell you want the field in.
 (vl-load-com)
   (while
     (and
         (setq Obj
     (while
                (if (eq :vlax-true
                      (vla-hittest
                        (setq tObj
                            (vlax-3D-point pt)
       (strcat
           (vl-princ-to-string
             (vla-get-Objectid Obj))
               ">%).Area \\f \"%lu2%pr2\">%")))
 (princ))
Thank you for your solution. For some reason, when I try to implement it using polylines, the field in cell shows ####. Any ideas on how to fix it?
Thank you!
