Hello
I'm from Romania so please pardone my english.
I have autocad 2007 and i have a problem writing a script.
I have lots of drawing files exported from a program called X-Steel and i have to plot them verry quickly.
The problem is that the lines have different thickness and when i plot them on paper you can't distinguish the linesbecause they are to thick.
Now I can resolve that by opening the file, giving 2 explode commands and give a select all command and change the line thicknes. And then give a plot command and selecting the last plot settings.
I have made a script that looks like this:
"_.zoom _e
plot
*Cancel*
close y"
But i would like to make someting like this
zoom extents
select all
explode select all
explode select all
select line weight 0
plot
select plotter (maybe can give the plotter name because i have multiple plotters)
plot area: extents
fit to paper
number of copies : 2
shade plot Wireframe
Plot style table monochrome
landscape
center the plot
and of course paper size A3 or A4
then close drawing
and don't save.
And can I make a script to run for an entire folder or multiple files, or automaticaly when i open the drawing file?
I'm attaching a sample file
Oh yeah and another question:in the customize user interface i would like to add assign a key to the run script command and i can't do it:cry:
Please help
Thank you
4971 - elemrajz.zip
Why not make a LISP and run that using a Script - it would be much more flexible.
Also, may I ask why you are exploding?
Lee
Lee
Because i never worked ever with a LISP
The exploding is because i have blocks in my drawing and can't or don't know how to change the lineweight otherwise
The truth is that I really don't know that much about scripts and LISP = zero
I will have to look it up on google when i have time because i'm working and have a busy schedule
But if you have some time could you help me writing a LISP with those commands that i have tried to explain in my first post?
Thank you
Thank you VVA I will read those threads.
I've found some LISP tutorials and i will get back if i have some new questions
I cannot use this damn plotdwgs
I load the plotdwgs.lsp and then :
Command: _appload plotdwgs.lsp successfully loaded.
Command:
Command:
Command: pd
Plot Drawings
; error: quit / exit abort
Command: screw it i'm getting me a beer
verry frustrating
What the hek do i have to do to get this thing working?
