I have this vba code, which I call from vb program with the following batch file. It works fine, except that once the vba program is complete it needs the user to close AutoCAD to continue. Is there any way I can have a vba program close AutoCAD?
I tried using SendCommand "Exit" and it seems to just confuse AutoCAD.
Batch File:
call "C:\[...]\Acad.exe" /b "C:\plot\plot.scr"
exit
VBA Code:
Public Sub Main()
   Dim strPlotSize As String
   Dim strPrinterType As String
   Dim docCurrentDrawing As AcadDocument
   Dim strFileName As String
   Dim acState As AcadState
   Dim objWin As Object
   ' Reserved for Debugging
   'UserForm1.Show
   ' Read printer preferances
   Read_File ("C:\plot\plot_config.txt")
   strPrinterType = cDL(1)
   cDL.Remove (1)
   strPlotSize = cDL(1)
   cDL.Remove (1)
   ' Read list of files
   Read_File ("C:\plot\batch_plot.txt")
   ' Open in read-only mode and run LISP file
   For intList = 1 To intCount
       Set docCurrentDrawing = Application.Documents.Open(cDL.Item(intList), vbReadOnly)
       strFileName = Replace(docCurrentDrawing.Name, ".dwg", ".pdf")
       docCurrentDrawing.SendCommand ("CADLock" & vbCr)
       GoTo Wait
Continue:
       ' Print Page and close document
       ReleasePrint strPrinterType, strPlotSize
       docCurrentDrawing.Close (False)
       For lngVbaHold = 1 To 50000
           DoEvents
       Next
      ' Close printed PDF document
       CloseApp strFileName, ""
       Next
       CloseApp Replace(cDL.Item(intList), ".dwg", ".pdf"), ""
       Next
   On Error Resume Next
   Application.ActiveDocument.SetVariable "FILEDIA", 1
   End ' End of Program
Wait:
   Set acState = Application.GetAcadState
   If acState.IsQuiescent Then
       GoTo Continue
   Else
       DoEvents
       GoTo Wait
   End If
End Sub
There's a way to shut down processes from the Windows command prompt using taskkill, but it's only available on certain versions of Windows. You can find it elsewhere and download it, just do a google search for "taskkill.exe". You could then make it into a one-line batch file and you're done.
Hope that helps a bit. ^.^
