I am having a little difficulty doing this since I am completely new on 64bit acad and system. I am trying to find out what are the right functions to call. I have a modified VBA code that I use to copy UCS from one dwg to another. This code works flawless in a 32bit but once we installed 64bit acad 2009 the code does not run. All I get is this error:
(Compile error: Function or interface marked as restricted, or the function uses an Automation type not supported in Visual Basic)
Here is where I get the error:
Public Function GetAcadHwnd() As Long
GetAcadHwnd = GetParent(GetParent(ThisDrawing.hwnd))
End Function
From what I have been re-searching the Hwnd is not the same in a 64bit system.
Any help is greatly appreciated.
thanks.
