I'm having a strange problem - or at least strange behavior - in migrating from ACAD Electrical 2009 to 2010.
When I start 2010, the command window shows the following:
 Customization file loaded successfully. Customization Group: ELECTRICAL
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: IMPRESSION
Customization file loaded successfully. Customization Group: AUTODESKSEEK
Customization file loaded successfully. Customization Group: GLENS_CUI_FILE
Customization file loaded successfully. Customization Group: EXPRESS
Regenerating model.
Loading Electrical modules...
Loader application completed.
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
DInfo © by Lee McDonnell Loaded.
Type "DINFO" to invoke...
Command:
Command: *Cancel*
Command: *Cancel*
Command: op
OPTIONS
Customization file loaded successfully. Customization Group: WD2CAD
Command:
Command:
Type "DINFO" to invoke...; [color=red]error: Automation Error. Problem in loading[/color] [color=red]VBA[/color]
loaded.
Command:
Command: menubar
Enter new value for MENUBAR <1>:
Command:
MENUBAR
Enter new value for MENUBAR <1>: 0
Command:
MENUBAR
Enter new value for MENUBAR <0>: 1
As it loads Lee's DINFO LISP the first time, all looks fine. Then, I type OP to get to the options dialog box and load a profile so that all my menus are where I want them to be. As it loads the menu customizations and reloads DINFO, I get an error loading VBA. (flagged red) (Why it loads it twice is also a good question, I'll check on that next.)
Further, the menu bar is not visible at the top of the screen, so i enter MENUBAR in the command window, and AutoCAD reports that it is on (1) so I turn it off, then turn it back on again, and it then shows up.
THIS is why I waited 2 months until I got a short break in workload to attempt to upgrade! So far I have 4 hours or so logged installing then repairing and migrating settings.
Any thoughts or hints would be appeciated.
Hi,
Firstly, I feel honoured that you are using my DINFO LISP :D
VBA is not supported in the standard release of ACAD 2010. You will need to download an add-on pack.
Try typing VBAIDE in 2010, and see what appears :)
Lee
Ok, I'm downloading and installing the VBA support module, but why does DINFO appear to load properly the first time through?
I'm thrilled to have found your program, impressed by your coding ability and awed by your willingness to write code for people who often appear to expect you to do it free and fast.
I guess that the switch from VBA to .net is happening sooner that I thought, I guess I'll switch from learing VBA to .net. gumble grumble grumble.
Glen
DINFO runs on LISP which is still supported on 2010 :)
Thanks - I get enjoyment from writing the programs, and also learn a great deal too.
Yeah, a lot of the guys here are going that way - a good person to talk to would be SeanT on here. - he's all clued up on the VBA side of things :)
Lee
Lee
Hey Lee, thanks for the plug. :)
Glen
No need to grumble . . . . well, maybe a little. VB.NET has a bit more of a learning curve but the extended functionality makes many task easier than if they were coded in VBA.
Another wierd thing I have discovered - once I load my profile, I can no longer get to help. If I hit F1 after starting 2010, I get the standard help screen. I load my profile, then hit F1 again and get a dialog box "Cannot find help file: acad.chm". Perhaps I need to recreate my profile nativly in 2010.
It should not be this difficult.
:? Ok, I checked the thread that Lee pointed me at, and followed the advice there. acad.chm does not exist on my C drive anywhere, but the help directory is/was full of .chm files (including acad180.chm - which I think is the help file for 2010, not acad181.chm) (no dig intended, just fyi).
Rather than messing about with trying to re-install help files, I tried getting help before loading my 2009 profile. It worked fine, so I reconfigured my workspace from scratch in 2010 and saved a new profile. Help still works. If I load the 2009 profile, I get the error message - but if I then load the 2010 profile, help works again.
I think that there must be something in the 2009 profile that is incompatable with or corrupts the file name or path for 2010's help function. I don't know why it would be changing anything in that area, but that's my story and I'm sticking with it.
Hope this helps someone else.
Glen
