Our office has a lisp routine which can tell the user what the current drawing scale is, aptly named DWG_SCAL. It works in conjuction with the tracewid factor. We have been using this for years and love it. Granted, it was created before annotation evolved but we are still "holding on". I am trying to update our Section Title and Typical Detail blocks to include fields such as filename, originator, etc. I would like to include our DWG_SCAL lisp routine as a field but am not sure if the code written for the lisp routine works for "field code". Is it possible to use a lisp routine as a field? If so, how?
Assuming that your lisp routine sets the drawing scale as a variable, create a Field using LispVariable as the Field Name.
or
Create a Field > Object > Object type (select Viewport) > Custom Scale
or
You will need the variable to be global, else it will be set to nil when the LISP function completes. :wink:
Forgive my ignorance but when I choose the lispvariable field category I only have a few different lisp variables to select. What exactly do I need to select?
Would you be able to post your LISP code - the variable would be the one that is bound to the drawing scale, but without seeing the LISP, it is impossible to know what that variable is called. :)
Use can use
 <Your code goes here> [/ code] tags to get around the smiley issue.
You can either select the LISP Variable: DWG_SC from the LispVariable section of the FIELDS dialog, or, this should insert it for you:
[code]
(defun c:fld  (/ Scale pt doc spc)
 (vl-load-com)
 (if (and (SETQ SCALE (GETVAR "TRACEWID"))
          (cond ((= scale 192)
                 (setq DWG_SC "SCALE\042 = 1/16\042 = 1'-0"))
                ((= scale 128)
                 (setq DWG_SC "SCALE\042 = 3/32\042 = 1'-0"))
                ((= scale 96)
                 (setq DWG_SC "SCALE\042 = 1/8\042 = 1'-0"))
                ((= scale 64)
                 (setq DWG_SC "SCALE\042 = 3/16\042 = 1'-0"))
                ((= scale 48)
                 (setq DWG_SC "SCALE\042 = 1/4\042 = 1'-0"))
                ((= scale 32)
                 (setq DWG_SC "SCALE\042 = 3/8\042 = 1'-0"))
                ((= scale 24)
                 (setq DWG_SC "SCALE\042 = 1/2\042 = 1'-0"))
                ((= scale 16)
                 (setq DWG_SC "SCALE\042 = 3/4\042 = 1'-0"))
                ((= scale 12)
                 (setq DWG_SC "SCALE\042 = 1\042 = 1'-0"))
                ((= scale
                 (setq DWG_SC "SCALE\042 = 1 1/2\042 = 1'-0"))
                ((= scale 4)
                 (setq DWG_SC "SCALE\042 = 3\042 = 1'-0"))
                ((= scale 2)
                 (setq DWG_SC "SCALE\042 = 6\042 = 1'-0"))
                ((= scale 1)
                 (setq DWG_SC "FULL SCALE"))
                ((<= SCALE 0.99)
                 (SETQ DWG_SC "TRACEWID IS NOT SET"))
                (t nil))
          (setq pt (getpoint "\nSelect Point for Field: ")))
     (setq doc (vla-get-ActiveDocument
                 (vlax-get-Acad-Object))
           spc (if (zerop (vla-get-activespace doc))
                 (if (= (vla-get-mspace doc) :vlax-true)
                   (vla-get-modelspace doc)
                   (vla-get-paperspace doc))
                 (vla-get-modelspace doc)))
     (vla-addMText spc
       (vlax-3D-point pt) 0
       "%<\\AcVar.17.0 Lisp.dwg_sc>%")))
 (princ))
Use can use
[code]
 (vl-load-com)
                ((= scale 128)
                ((= scale 96)
                ((= scale 64)
                ((= scale 48)
                ((= scale 32)
                ((= scale 24)
                ((= scale 16)
                ((= scale 12)
                ((= scale
                ((= scale 4)
                ((= scale 2)
                ((= scale 1)
                ((<= SCALE 0.99)
                (t nil))
     (vla-addMText spc
 (princ))
Okay, the field loaded but when I insert the block into a new drawing instead of the attribute reading as the current scale it looks like this, ####
Use can use
[code]
 (vl-load-com)
                ((= scale 128)
                ((= scale 96)
                ((= scale 64)
                ((= scale 48)
                ((= scale 32)
                ((= scale 24)
                ((= scale 16)
                ((= scale 12)
                ((= scale
                ((= scale 4)
                ((= scale 2)
                ((= scale 1)
                ((<= SCALE 0.99)
                (t nil))
     (vla-addMText spc
 (princ))
Okay, I got it to work but instead of the field just giving the current scale it adds Scale" in front of the scale, for example: SCALE" = 3/4" = 1'-0". Is there a way for the field attribute to only read 3/4" = 1'-0"?
That's only what you had before.
I have changed your original code to remove the "SCALE"
 (vl-load-com)
                 (setq DWG_SC [color=Red][b]"1/16\042 = 1'-0"[/b][/color]))
                ((= scale 128)
                 (setq DWG_SC [b][color=Red]"3/32\042 = 1'-0"[/color][/b]))
                ((= scale 96)
                 (setq DWG_SC [b][color=Red]"1/8\042 = 1'-0"[/color][/b]))
                ((= scale 64)
                 (setq DWG_SC [color=Red][b]"3/16\042 = 1'-0"[/b][/color]))
                ((= scale 48)
                 (setq DWG_SC [b][color=Red]"1/4\042 = 1'-0"[/color][/b]))
                ((= scale 32)
                 (setq DWG_SC [b][color=Red]"3/8\042 = 1'-0"[/color][/b]))
                ((= scale 24)
                 (setq DWG_SC [b][color=Red]"1/2\042 = 1'-0"[/color][/b]))
                ((= scale 16)
                 (setq DWG_SC [b][color=Red]"3/4\042 = 1'-0"[/color][/b]))
                ((= scale 12)
                 (setq DWG_SC [b][color=Red]"1\042 = 1'-0"[/color][/b]))
                ((= scale
                 (setq DWG_SC [color=Red][b]"1 1/2\042 = 1'-0"[/b][/color]))
                ((= scale 4)
                 (setq DWG_SC [color=Red][b]"3\042 = 1'-0"[/b][/color]))
                ((= scale 2)
                 (setq DWG_SC [b][color=Red]"6\042 = 1'-0"[/color][/b]))
                ((= scale 1)
                ((<= SCALE 0.99)
                (t nil))
     (vla-addMText spc
 (princ))
 (vl-load-com)
                 (setq DWG_SC [color=red][b]"1/16\042 = 1'-0"[/b][/color]))
                ((= scale 128)
                 (setq DWG_SC [b][color=red]"3/32\042 = 1'-0"[/color][/b]))
                ((= scale 96)
                 (setq DWG_SC [b][color=red]"1/8\042 = 1'-0"[/color][/b]))
                ((= scale 64)
                 (setq DWG_SC [color=red][b]"3/16\042 = 1'-0"[/b][/color]))
                ((= scale 48)
                 (setq DWG_SC [b][color=red]"1/4\042 = 1'-0"[/color][/b]))
                ((= scale 32)
                 (setq DWG_SC [b][color=red]"3/8\042 = 1'-0"[/color][/b]))
                ((= scale 24)
                 (setq DWG_SC [b][color=red]"1/2\042 = 1'-0"[/color][/b]))
                ((= scale 16)
                 (setq DWG_SC [b][color=red]"3/4\042 = 1'-0"[/color][/b]))
                ((= scale 12)
                 (setq DWG_SC [b][color=red]"1\042 = 1'-0"[/color][/b]))
                ((= scale
                 (setq DWG_SC [color=red][b]"1 1/2\042 = 1'-0"[/b][/color]))
                ((= scale 4)
                 (setq DWG_SC [color=red][b]"3\042 = 1'-0"[/b][/color]))
                ((= scale 2)
                 (setq DWG_SC [b][color=red]"6\042 = 1'-0"[/color][/b]))
                ((= scale 1)
                ((<= SCALE 0.99)
                (t nil))
     (vla-addMText spc
 (princ))
I really appreciate your assistance and thanks for being patient but it still reads SCALE" = 1/2" = 1'-0".
This does not happen for me - have you closed the current drawing and reloaded the LISP file?
Use can use
[code]
 (vl-load-com)
                ((= scale 128)
                ((= scale 96)
                ((= scale 64)
                ((= scale 48)
                ((= scale 32)
                ((= scale 24)
                ((= scale 16)
                ((= scale 12)
                ((= scale
                ((= scale 4)
                ((= scale 2)
                ((= scale 1)
                ((<= SCALE 0.99)
                (t nil))
     (vla-addMText spc
 (princ))
Hi.....Why use TRACEWID?? Why not CANNOSCALE?? just wondering.
T2L
T2L
I'm just manipulating the old routine. o:)
You are a genius!!!!! I had to close AutoCAD completely and reload the lisp routines but once I did that everything seems to be working fine!
THANK YOU SO MUCH FOR YOUR ASSISTANCE!
:D:D:D:D:D:D:D
:D:D:D:D:D:D:D
No problem - happy to help :)
