I need a lisp : scale drawing with value dimension no change. Help me!
You could try scalining it down
then adjucting the dimfac to 1/ x , x = the scale
Could you show us what you have attempted to write, and we can help you improve it :thumbsup:
Flowerrobot called the easiest way. The only thing I could add to it would be to put all your dimensions on a single layer, that way you can select all of them and change the scale as needed. Unfortunately, the LISP to determine if an object has been scaled or not and then adjust all the possible dimensions associated with that object might be difficult to do. If you're talking about a viewport scale that might be easier, but it would likely do the same exact thing in the end: changing the overall scale on the dimension, which again, you can do simply by selecting them and editing the number.
