Hi All
One of the staff from my work asked me for a method of counting the number of instances of a string begining with a character on a specific layer
That gave me the following idea which i felt the community may find useful
(setq sset (ssget "X" (list(cons 1 "A*")(cons 8 "Exlayer"))))
The asterix (*) allows for wildcard filtering of entities.
This also works with *char* for searching mid string
Ollie
Thanks for sharing that Ollie,
another method:
(defun c:tcnt  (/ ss tStr)
 (vl-load-com)
 (if (and (setq ss (ssget "_X" (list (cons 0 "*TEXT"))))
          (setq tStr (getstring t "\nText to Search For: ")))
     (setq ss (vl-remove-if-not
                (function
                  (lambda (x)
                    (wcmatch
                      (cdr (assoc 1 (entget x))) tStr)))
              (mapcar 'cadr (ssnamex ss))))
     (if (not (zerop (length ss)))
       (princ (strcat (rtos (length ss) 2 0) " Item(s) Found."))
       (princ "\nNo Matching Text Strings. ")))
   (princ "\n<!> No Text Found in Drawing <!>"))
 (princ))
No Probs its good to give back to the community for a change :)
Worth noting. Where I place "A*" as a literal string a variable can be used
Ollie
That is awsome. Does it work in a similar method to Regex for PERL?
I can't be certain about that, but wildcard characters are pretty standard. :)
Ollie,
Note that your example is Case sensitive. To make it non-case sensitive use this:
(setq sset (ssget "X" (list(cons 1 "[aA]*")(cons 8 "Exlayer"))))
For another example of wcmatch within ssget see this example by Evgeniy
Here I explained how it works:
http://www.theswamp.org/index.php?topic=21058.msg255696#msg255696
He is a master of wildcard characters & there usage.
Thanks CAB
I have had a chance to play about with the wildcard system and it is more or less Regex for perl.
[a-f]* will find asdf but not Asdf (match chars from class [] 0 or more times
the only main difference I have noticed so far is that '\' chars such as \w, \d don't work
Ollie
another method:
 (vl-load-com)
                (function
                  (lambda (x)
                    (wcmatch
 (princ))
why not ask for the filter, then select the text. you are forcing the routine to iterate through every piece of text in the drawing.
Good point Alan - not sure what I was thinking when I wrote that :unsure:
