hi...can someone teach me how to find min and max value from text file....thanks..
Depends on the format of the text file, but your code would probably look something like this:
(setq fileID "path\\filename.txt" linLst '())
(setq file (open fileID "R"))
(while (setq line (read-line file))
 (setq linLst (cons line linLst))
(close file)
(setq maxNum (apply 'max linLst))
(setq minNum (apply 'min linLst))
May need a few "distof"'s in there...
(if (setq file (getfiled "Select File" "" "txt" )
   (setq file (open file "r"))
   (while (setq nl (read-line file))
     (setq lst (cons (distof nl) lst)))
   (close file)
   (apply 'max lst)
   (apply 'min lst)
After you get the atoms in the list LST:
(eval (cons 'max LST))
o.o Slick solution, very nice!
I like it :D
  • 10 years later...
And how to do the same with the list? Choose a coordinate from the list with a minimum and maximum value of Z.
List:
((76751.7 53561.3 765.102) (76751.7 53561.3 765.102) (76758.6 53565.1 767.424) (76750.7 53565.9 766.755))
minimum:
maximum
You can sort a list on the z value caddr. look at 1st entry and last
;sort on x
(setq lst
 (vl-sort co-ordsxy
 (function (lambda (e1 e2)
 (< (car e1) (car e2)))
;sort on z
(setq lst
 (vl-sort co-ordsxy
 (< (caddr e1) (caddr e2)))
(setq minz (nth 0 lst))
(setq maxz (nth (- (length lst) 1) lst))
Sorting is inefficient when only an extremum is required.
You may find existing functions covering this operation here and a function specific to finding the minimum/maximum Z-coordinate here.
Thank you very much, Lee Mac.
Nice Lee as usual did not even think about iterate over list check max min. Easy to add a couple more conds and make a library routine for min max X Y Z
I use this style of min/max point list search a lot:
(apply 'max (mapcar 'car lst))
-David
