I started to develop a lisp but i realized it's a little out of ma league so i need some help. This is the desired work flow. I need to insert a specific block named roomtag. This block has an attribute named roomnumber. When i insert this block i need to be prompted to select the room number. Room number can be text, mtext or another attribute. When selected, values of this entities should become roomnumber attribute value. Any ideas?
Sorry for my ignorance, Isnt what you are asking coming defult?
Or do you have alot of attributes and only want to be able to edit that one?
(defun c:pen ()
(defun attget (ss1 / en edata)
 (if ss1
   (setq en (ssname ss1 0))
   (setq edata (entget en))
   (setq blockdata nil)
   (setq edata (entget (entnext (cdr (assoc -1 edata)))))
   (while (not(= (cdr (assoc 0 edata)) "SEQEND"))
    (setq blockdata (cons (cons  (cdr (assoc 2 edata)) (cdr (assoc 1 edata))) blockdata))
   (alert "Their is no block")
   (exit)
(defun attput (ss1 / en edata)
   (entmod (subst (cons 1 (cdr (assoc (cdr (assoc 2 edata)) blockdata)))(assoc 1 edata) edata))
(setq InPoint (getpoint "\nSelect insetion point :"))
(Setq TheString (getstring "\nWhat is the room number :"))
(setq TheScale (getint "What is the scale of insertion? :"))
(setvar "attdia" 0)
;What is the one that turns it off completly?
(command "_.Insert" "roomtag" InPoint TheScale TheScale 0)
(setq TheEntity (ssget (entlast)))
(attget TheEntity)
(setq blockdata (subst (cons "roomnumber" TheString) (assoc "roomnumber" blockdata) blockdata))
(attput TheEntity)
(princ Block Created)
I have two attributes but i want to update only one.
Maybe i did not explain what "select" means. When i'm prompted for room number i want to select text, mtext or some other attribute to get the value for my roomnumber attribute.
Ahh i see now, Sorry carnt help now the bus is calling me :(, Neither will the code above be any use :(
This should help you along the way (will get the text out)
Nm = entity data
(cdr (assoc 1 (entget NM)))
Try this mate:
(defun c:RmNo (/ doc spc str pt Blk gr dat ent)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument
             (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc))   str "")
 (if (or (tblsearch "BLOCK" "roomtag")
         (findfile "roomtag.dwg"))
   (if (setq pt (getpoint "\nSpecify Point for Block: "))
       (setq Blk
         (vla-insertblock spc
           (vlax-3D-point pt) "roomtag.dwg" 1. 1. 1. 0.))
       (princ "\nSelect or Specify Room Number: ")
       (vl-catch-all-apply
         (function
           (lambda ( )
             (while
                 (setq gr (grread t 15 2) dat (cadr gr))
                 (cond
                   ((and (= 3 (car gr)) (listp dat))
                    (if (setq ent (car (nentselp dat)))
                      (if (vl-position
                            (cdr (assoc 0 (entget ent)))
                              '("TEXT" "MTEXT" "ATTRIB"))
                          (setq str
                            (vla-get-TextString
                              (vlax-ename->vla-object ent))) nil)
                        (princ "\n** Invalid Object Selected **"))
                      (princ "\n** Nothing Selected **")))
                   ((= 2 (car gr))
                    (cond ((<= 32 dat 126)
                           (princ (chr dat))
                           (setq str (strcat str (chr dat))))
                          ((= 8 dat)
                           (and (< 0 (strlen str))
                                (princ (strcat (chr  (chr 32) (chr ))
                                (setq str (substr str 1 (1- (strlen str))))))
                          ((= dat 13) nil)))
                   ((= 25 (car gr)) nil)
                   (t t)))))))
       (foreach att
         (append
           (if
             (not
               (vl-catch-all-error-p
                 (setq atArr
                   (vl-catch-all-apply
                     'vlax-safearray->list
                     (list
                       (vlax-variant-value
                         (vla-GetAttributes Blk))))))) atArr)
           (if
             (not
                 (setq caArr
                   (vl-catch-all-apply
                     (list
                       (vlax-variant-value
                         (vla-GetConstantAttributes Blk))))))) caArr))
         (if (eq "ROOMNUMBER"
                 (strcase
                   (vla-get-TagString att)))
           (vla-put-TextString att str))))
     (princ "\n<< No Point Specified >>"))
   (princ "\n<< Block Not Found >>"))
 (princ))
Try this mate:
 (vl-load-com)
       (setq Blk
       (vl-catch-all-apply
         (function
           (lambda ( )
             (while
                 (cond
                      (if (vl-position
                          (setq str
                            (vla-get-TextString
                   ((= 2 (car gr))
                           (princ (chr dat))
                          ((= 8 dat)
                          ((= dat 13) nil)))
                   (t t)))))))
       (foreach att
         (append
           (if
             (not
                 (setq atArr
                   (vl-catch-all-apply
                     (list
                       (vlax-variant-value
           (if
             (not
                 (setq caArr
                   (vl-catch-all-apply
                     (list
                       (vlax-variant-value
                 (strcase
 (princ))
I tried it but i get this message
Specify Point for Block: Block roomtag references itself
; error: Automation Error. Self reference
I put the roomtag.dwg file with roomtag block in a folder which i put in a support folders in options. Maybe i'm wrong.
If the roomtag.dwg contains a roomtag block - then there will be a self reference issue.
You could open the roomtag.dwg, explode the block within it, and then WBLOCK it to make the block - a much better way to approach things. :)
Thanks man. Works like a charm!
You rule....!!!
This is way out my lisp league.
You rule....!!!
Happy to help dude - don't worry, its only practice :)
