N_461 Posted September 7, 2010 Posted September 7, 2010 something with the descriptions column?? initially i couldn't get the other layers to populate unless i removed description and used nil... Quote
antistar Posted September 8, 2010 Posted September 8, 2010 Wouldn't this be easier to deal with and edit? (defun c:Foo nil (mapcar '(lambda (x) (apply 'MakeLayer x)) '(("CEN" 6 "CENTER" 0.18 T 0 nil) ("DIMS" -1 nil 0.18 T 1 "Dimensions") ) ) (princ) ) Alan, your routine displays this error message window in CAD2002: Command: ap APPLOAD FOO.LSP successfully loaded. Command: Command: foo ; error: no function definition: nil Quote
N_461 Posted September 8, 2010 Posted September 8, 2010 Alan's routine was an edit to Lee's. you have to edit Lees with this section. Quote
Lee Mac Posted September 8, 2010 Posted September 8, 2010 To remove the ambiguity from this thread: (defun MakeLayer ( name colour linetype lineweight willplot bitflag description ) ;; © Lee Mac 2010 (or (tblsearch "LAYER" name) (entmake (append (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 name) (cons 70 bitflag) (cons 290 (if willplot 1 0)) (cons 6 (if (and linetype (tblsearch "LTYPE" linetype)) linetype "CONTINUOUS" ) ) (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7)) (cons 370 (fix (* 100 (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0) ) ) ) ) (if description (list (list -3 (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description)) ) ) ) ) ) ) ) (defun c:MakeLayers nil ;; © Lee Mac 2010 [color=blue][b] ;; Specifications: [/b][b] ;; Description Data Type Remarks ;; ----------------------------------------------------------------- ;; Layer Name STRING Only standard chars allowed ;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256 ;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS. ;; Layer Lineweight REAL may be nil, 0 <= x <= 2.11 ;; Plot? BOOLEAN T = Plot Layer, nil otherwise ;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked ;; Description STRING may be nil for no description [/b][b] ;; Function will return list detailing whether layer creation is successful.[/b][/color] ( (lambda ( lst ) (mapcar 'cons (mapcar 'car lst) (mapcar (function (lambda ( x ) (apply 'MakeLayer x) ) ) lst ) ) ) '( [color=blue][b] ; Name Colour Linetype Lineweight Plot? BitFlag Description[/b][/color] ( "CEN" 6 "CENTER" 0.18 T 0 nil ) ( "DIMS" -1 nil 0.18 T 1 "Dimensions" ) ( "HAT" 3 nil 0.18 T 5 nil ) ( "HID" 4 "HIDDEN" 0.15 T 0 "Hidden" ) ( "LOGO" 176 nil 0.09 T 0 "For Logo" ) ( "OBJ" -2 nil 0.40 T 3 nil ) ( "PAPER" 5 "PHANTOM" nil nil 6 nil ) ( "PHAN" 6 "PHANTOM" 0.18 T 0 nil ) ( "TITLE" 176 nil nil T 1 "For Title" ) ( "TXT" 7 nil nil T 0 nil ) ) ) ) Edit table as necessary. Quote
alanjt Posted September 8, 2010 Posted September 8, 2010 Alan, your routine displays this error message window in CAD2002: Command: ap APPLOAD FOO.LSP successfully loaded. Command: Command: foo ; error: no function definition: nil I wonder if you aren't allowed to put nil instead of (/), when defining the function.What happens when you change (defun c:foo nil for (defun c:foo (/) ? Quote
Lee Mac Posted September 8, 2010 Posted September 8, 2010 I think it was because they were loading your function without mine - Hence getting (apply 'nil x) Quote
alanjt Posted September 8, 2010 Posted September 8, 2010 I think it was because they were loading your function without mine - Hence getting (apply 'nil x) I thought that, but assumed they would receive an 'invalid function' error. Oh well. I still feel my contrib. is a lot easier to edit, etc. Quote
Lee Mac Posted September 8, 2010 Posted September 8, 2010 Oh well. I still feel my contrib. is a lot easier to edit, etc. Most definitely - hence why I used that way of phrasing it when posting above. Preaching to the converted mate Quote
antistar Posted September 9, 2010 Posted September 9, 2010 I changed to (defun c: foo (/) and displayed the same error. Command: foo ; error: no function definition: nil Command: Quote
alanjt Posted September 9, 2010 Posted September 9, 2010 I changed to (defun c: foo (/) and displayed the same error. Command: foo ; error: no function definition: nil Command: Then it's that you are missing Lee's subroutine "MakeLayer". What I posted will not create the layers, it still needs the MakeLayer sub to be loaded. Quote
Se7en Posted September 9, 2010 Posted September 9, 2010 I wonder if you aren't allowed to put nil instead of (/), when defining the function.What happens when you change (defun c:foo nil for (defun c:foo (/) ? Sidebar (nothing to do with the thread): Why have I started to see that lately? What is making you guys replace "(/)" with "nil"? Quote
Lee Mac Posted September 9, 2010 Posted September 9, 2010 Sidebar (nothing to do with the thread):Why have I started to see that lately? What is making you guys replace "(/)" with "nil"? I've done it a few times for kicks Quote
Lee Mac Posted September 9, 2010 Posted September 9, 2010 I changed to (defun c: foo (/) and displayed the same error. Command: foo ; error: no function definition: nil Command: Use my code in post #24 Quote
N_461 Posted September 14, 2010 Posted September 14, 2010 To remove the ambiguity from this thread: (defun MakeLayer ( name colour linetype lineweight willplot bitflag description ) ;; © Lee Mac 2010 (or (tblsearch "LAYER" name) (entmake (append (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 name) (cons 70 bitflag) (cons 290 (if willplot 1 0)) (cons 6 (if (and linetype (tblsearch "LTYPE" linetype)) linetype "CONTINUOUS" ) ) (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7)) (cons 370 (fix (* 100 (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0) ) ) ) ) (if description (list (list -3 (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description)) ) ) ) ) ) ) ) (defun c:MakeLayers nil ;; © Lee Mac 2010 [color=blue][b] ;; Specifications:[/b][/color] [color=blue][b] ;; Description Data Type Remarks[/b][/color] [b][color=blue] ;; -----------------------------------------------------------------[/color][/b] [b][color=blue] ;; Layer Name STRING Only standard chars allowed[/color][/b] [b][color=blue] ;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256[/color][/b] [b][color=blue] ;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS.[/color][/b] [b][color=blue] ;; Layer Lineweight REAL may be nil, 0 <= x <= 2.11[/color][/b] [b][color=blue] ;; Plot? BOOLEAN T = Plot Layer, nil otherwise[/color][/b] [b][color=blue] ;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked[/color][/b] [b][color=blue] ;; Description STRING may be nil for no description[/color][/b] [color=blue][b] ;; Function will return list detailing whether layer creation is successful.[/b][/color] ( (lambda ( lst ) (mapcar 'cons (mapcar 'car lst) (mapcar (function (lambda ( x ) (apply 'MakeLayer x) ) ) lst ) ) ) '( [color=blue][b] ; Name Colour Linetype Lineweight Plot? BitFlag Description[/b][/color] ( "CEN" 6 "CENTER" 0.18 T 0 nil ) ( "DIMS" -1 nil 0.18 T 1 "Dimensions" ) ( "HAT" 3 nil 0.18 T 5 nil ) ( "HID" 4 "HIDDEN" 0.15 T 0 "Hidden" ) ( "LOGO" 176 nil 0.09 T 0 "For Logo" ) ( "OBJ" -2 nil 0.40 T 3 nil ) ( "PAPER" 5 "PHANTOM" nil nil 6 nil ) ( "PHAN" 6 "PHANTOM" 0.18 T 0 nil ) ( "TITLE" 176 nil nil T 1 "For Title" ) ( "TXT" 7 nil nil T 0 nil ) ) ) ) Edit table as necessary. Thanks a million guys!! You def'ly helped me out a tonne, i just have another question, on Lee's initial routine, the linetypes loaded in automatically. What do i need to change in this code to get it to do the same thing? What i found was that as long as the lisp is in the same directory as the acad.lin and acadiso.lin files it worked. .... i also just tested to make sure, i completely purged my drawing, then ran the first lisp (old code) and presto! Quote
Lee Mac Posted September 14, 2010 Posted September 14, 2010 I didn't really want to modify the sub, so try this: (defun MakeLayer ( name colour linetype lineweight willplot bitflag description ) ;; © Lee Mac 2010 (or (tblsearch "LAYER" name) (entmake (append (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 name) (cons 70 bitflag) (cons 290 (if willplot 1 0)) (cons 6 (if (and linetype (tblsearch "LTYPE" linetype)) linetype "CONTINUOUS" ) ) (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7)) (cons 370 (fix (* 100 (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0) ) ) ) ) (if description (list (list -3 (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description)) ) ) ) ) ) ) ) (defun c:MakeLayers nil (vl-load-com) ;; © Lee Mac 2010 [color=purple][b];; Specifications: [/b][b];; Description Data Type Remarks ;; ----------------------------------------------------------------- ;; Layer Name STRING Only standard chars allowed ;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256 ;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS. ;; Layer Lineweight REAL may be nil, 0 <= x <= 2.11 ;; Plot? BOOLEAN T = Plot Layer, nil otherwise ;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked ;; Description STRING may be nil for no description [/b][b] ;; Function will return list detailing whether layer creation is successful. [/b][/color] ( (lambda ( lst / lts ) (setq lts (vla-get-Linetypes (vla-get-ActiveDocument (vlax-get-acad-object)))) (mapcar 'cons (mapcar 'car lst) (mapcar (function (lambda ( x ) (and (caddr x) (or (tblsearch "LTYPE" (caddr x)) (vl-catch-all-apply 'vla-load (list lts (caddr x) "acad.lin")) ) ) (apply 'MakeLayer x) ) ) lst ) ) ) '( [color=purple][b] ; Name Colour Linetype Lineweight Plot? BitFlag Description[/b][/color] ( "CEN" 6 "CENTER" 0.18 T 0 nil ) ( "DIMS" -1 nil 0.18 T 1 "Dimensions" ) ( "HAT" 3 nil 0.18 T 5 nil ) ( "HID" 4 "HIDDEN" 0.15 T 0 "Hidden" ) ( "LOGO" 176 nil 0.09 T 0 "For Logo" ) ( "OBJ" -2 nil 0.40 T 3 nil ) ( "PAPER" 5 "PHANTOM" nil nil 6 nil ) ( "PHAN" 6 "PHANTOM" 0.18 T 0 nil ) ( "TITLE" 176 nil nil T 1 "For Title" ) ( "TXT" 7 nil nil T 0 nil ) ) ) ) Quote
alanjt Posted September 15, 2010 Posted September 15, 2010 Glad to see you took to the mapcar+apply and single list for each layer formatting. Quote
Lee Mac Posted September 15, 2010 Posted September 15, 2010 Glad to see you took to the mapcar+apply and single list for each layer formatting. Yeah, seemed like a better method, thanks. Quote
alanjt Posted September 15, 2010 Posted September 15, 2010 Yeah, seemed like a better method, thanks. You're welcome. Anytime. Quote
N_461 Posted September 16, 2010 Posted September 16, 2010 i didn't really want to modify the sub, so try this: (defun makelayer ( name colour linetype lineweight willplot bitflag description ) ;; © lee mac 2010 (or (tblsearch "layer" name) (entmake (append (list (cons 0 "layer") (cons 100 "acdbsymboltablerecord") (cons 100 "acdblayertablerecord") (cons 2 name) (cons 70 bitflag) (cons 290 (if willplot 1 0)) (cons 6 (if (and linetype (tblsearch "ltype" linetype)) linetype "continuous" ) ) (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7)) (cons 370 (fix (* 100 (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0) ) ) ) ) (if description (list (list -3 (list "acaeclayerstandard" (cons 1000 "") (cons 1000 description)) ) ) ) ) ) ) ) (defun c:makelayers nil (vl-load-com) ;; © lee mac 2010 [color=purple][b];; specifications:[/b][/color] [color=purple][b];; description data type remarks[/b][/color] [b][color=purple] ;; -----------------------------------------------------------------[/color][/b] [b][color=purple] ;; layer name string only standard chars allowed[/color][/b] [b][color=purple] ;; layer colour integer may be nil, -ve for layer off, colour < 256[/color][/b] [b][color=purple] ;; layer linetype string may be nil, if not loaded, continuous.[/color][/b] [b][color=purple] ;; layer lineweight real may be nil, 0 <= x <= 2.11[/color][/b] [b][color=purple] ;; plot? Boolean t = plot layer, nil otherwise[/color][/b] [b][color=purple] ;; bit flag integer 0=none, 1=frozen, 2=frozen in vp, 4=locked[/color][/b] [b][color=purple] ;; description string may be nil for no description[/color][/b] [color=purple][b];; function will return list detailing whether layer creation is successful. [/b][/color] ( (lambda ( lst / lts ) (setq lts (vla-get-linetypes (vla-get-activedocument (vlax-get-acad-object)))) (mapcar 'cons (mapcar 'car lst) (mapcar (function (lambda ( x ) (and (caddr x) (or (tblsearch "ltype" (caddr x)) (vl-catch-all-apply 'vla-load (list lts (caddr x) "acad.lin")) ) ) (apply 'makelayer x) ) ) lst ) ) ) '( [color=purple][b] ; name colour linetype lineweight plot? Bitflag description[/b][/color] ( "cen" 6 "center" 0.18 t 0 nil ) ( "dims" -1 nil 0.18 t 1 "dimensions" ) ( "hat" 3 nil 0.18 t 5 nil ) ( "hid" 4 "hidden" 0.15 t 0 "hidden" ) ( "logo" 176 nil 0.09 t 0 "for logo" ) ( "obj" -2 nil 0.40 t 3 nil ) ( "paper" 5 "phantom" nil nil 6 nil ) ( "phan" 6 "phantom" 0.18 t 0 nil ) ( "title" 176 nil nil t 1 "for title" ) ( "txt" 7 nil nil t 0 nil ) ) ) ) perfect, thanks lee- been a great help Quote
