  • Replies 59
  • Lee Mac
    22
  • SteveK
    20
  • CAB
    8
  • MSasu
    6
Ta!
That's a good alternative.
Glad you like it. I have never seen the TabSelected property exposed to LISP.
Put it on the wishlist I think :)
vla-get-TabSelected
CAB, about your layout select program. I want to run it from another lisp to get the tab list. After I run it is there a way to retrieve the tablst variable? Or is setting tablst as a global variable the only way?
Thanks.
Steve,
Use this version & it will return the list or nil if none selected.
(defun GetTabList (/ dclfile dcl# layouts ptr tablist)
 (setq dclfile "LayoutSelect.dcl")
 (cond
   ((< (setq dcl# (load_dialog dclfile)) 0) ; Error
    (prompt (strcat "\nCannot load " dclfile "."))
   ((not (new_dialog "layoutselect" dcl#)) ; Error
    (prompt (strcat "\nProblem with " dclfile "."))
   (t ; No DCL problems: fire it up
    (setq layouts (vl-sort (layoutlist) '<))
    (start_list "layouts")
    (foreach one layouts
      (add_list one)
    (end_list)
   (action_tile "layouts" "(setq ptr $value)")
   (action_tile "ok" "(done_dialog 5)")
   (action_tile "cancel" "(done_dialog 1)")
    (setq action (start_dialog))
    (unload_dialog dcl#)
    (if (and ptr (= action 5)) ;  get the list of selections to list of numbers
      (setq ptr     (read (strcat "(" ptr ")"))
            tablist (mapcar '(lambda (x) (nth x layouts)) ptr))
   ) ; end cond T
 ) ; end cond
 tablist
You're quite welcome.
Just after midnight here so I'll say good night, guess you're just getting up. :)
Getting up? Lol no it's the afternoon, I'm gearing up for home time. I think it would be Lee just getting up. :D
  Lee Mac said:
Yes, it is a function defined in the ai_utils.lsp in the ACAD Support folder :)
Try it at the command line :)
Lee,
I couldn't find that file anywhere - any Idea?
  chulse said:
it returned nil
Oh right - perhaps Civil 3D doesn't have it :unsure:
  CAB said:
Try this:
(findfile "ai_utils.lsp")
Oops... yeah, I kinda forgot the extension :oops:
That did it! Thanks!
It was under
"C:\\program files\\autocad civil 3d 2010\\support\\ai_utils.lsp"
