Some Simple Autolisp Questions.
SteveK
FYI and a minor point.
(vl-load-com) is not needed for vl- functions but is required to be execuited once before any vla- vlax- or vlr- functions are used.
  • Replies 59
  • Lee Mac
    22
  • SteveK
    20
  • CAB
    8
  • MSasu
    6
I did not realise that - thanks Alan :thumbsup:
You welcome!
There is also possible to list all the entries in a specified definitions table – see below how to list all text styles defined in current drawing (may use MEMBER statement later to search if a particular style is in list):
(setq TStyleEntry (cdr (assoc 2 (tblnext "STYLE" 1)))
     TStylesList '())
(while TStyleEntry
(setq TStylesList (append TStylesList (list TStyleEntry))
      TStyleEntry (cdr (assoc 2 (tblnext "STYLE"))))
Regards
Another way:
(defun get_tbl_styles (/ tdef lst)
 (reverse
   (while (setq tdef (tblnext "STYLE" (not tdef)))
     (setq lst (cons (cdr (assoc 2 tdef)) lst)))))
@Lee Mac:
Indeed, concise solution!
  • 3 weeks later...
@Lee Mac:
Even more Concise:
(ai_table "BLOCK" 3)
How does that work Lee? ai_table isn't a function is it?
Yes, it is a function defined in the ai_utils.lsp in the ACAD Support folder :)
Try it at the command line :)
Thats handy. And the 3 is the sum of 1 & 2:
1 = Do not list Layer 0 and Linetype CONTINUOUS.
2 = Do not list anonymous blocks or anonymous groups.
How do you discover these things? :)
Mostly from others code, and just curiousity I suppose :)
The ACAD.dcl is a nice one to peruse also, some handy widgets in there. :)
  • 2 weeks later...
New Question: Retrieving a List of Selected Layouts...
I don't really want to start a new thread for a question so small, except if no one notices this question...
Does anyone know, when you select multiple layout tabs (with Ctrl), is there a way of outputting a list of the layout names of only those selected layouts?
The aim is to then do specific searches on only those selected tabs.
Appreciate any help.
Aside: As per the previous post I did a search for ACAD.dcl and nothing turned up.
To answer the aside first:
The ACAD.dcl is in a hidden folder :P
Something like this path:
C:\Users\<username>\AppData\Roaming\Autodesk\AutoCAD XXXX\RXX.0\enu\Support\
Regarding the main question:
Lee I don't think you've ever not been able to help me, now I'm worried no answer exists!
Though I would have thought there would be an answer, as Publish provides the layouts based on those selected, so it must retrieve it somehow.
About the aside: Ah, there ACAD.dcl is, it was hidden. I haven't made any dialog boxes yet, but I'm sure that'll come in handy when I do.
(setq layout (dos_multilist "Select Layouts" "Select layouts" (layoutlist)))
. :roll:
Thanks CAB!
Just so others know; if you also get an error: dos_multilist is a DOSLib function, so load DOSLib before using.
Bit different to what I expected but it outputs a list of layouts, so it does the job. :)
Yeah I haven't done any C++ so Daniels solution is over my head (not that CAB's isn't, but it's shorter :)).
I'm happy with CAB's, I'll just include a (load DOSLib) in my code.
Lee: yes, I am learning C++, but I only started learning about 2 days ago
lol, I'm sure if only you had a week you would understand his code. how are your efforts to knock over as many languages as you can in a year going?
I think CAB also included another solution in the Swamp thread, that didn't include the DosLib - you may be interested in.
Well, C++ is going to be a lot tougher to crack than LISP, but I shall have to see how I get on :)
I cannot see this other method you speak of, or at least maybe I need to have an account there to see it? Only the dos_multilist one.
Reply #4, I think you will need an account to see the attachments :)
