JerryG Posted June 23, 2009 Share Posted June 23, 2009 Hello all. My problem today is that I have created an Alignment, profile of that alignment, and a design profile with design elevations. But when I create my corridor it does not take on those design elevations from the profile. Ive set my baseline to be the new design profile, however it still will not take on the elevations I am giving it??? Any ideas of what I could try??? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Darin.Green Posted June 24, 2009 Share Posted June 24, 2009 Hello all.My problem today is that I have created an Alignment, profile of that alignment, and a design profile with design elevations. But when I create my corridor it does not take on those design elevations from the profile. Ive set my baseline to be the new design profile, however it still will not take on the elevations I am giving it??? Any ideas of what I could try??? Thanks in advance! When creating your corridor, are you selecting the finish grade within your profile, or are you selecting the existing grade? Quote Link to comment Share on other sites More sharing options...
JerryG Posted June 25, 2009 Author Share Posted June 25, 2009 Well it turns out I was doing everything right. It seams that when you ID a corridor assembly in plan view it gives the elevation of the existing grade not the assembly. So the whole time I thought it was not taking the design elevations until I turned on the Tin and Id'ed a Tin Line and low and behold it was right! Thanks for the response Darin. Quote Link to comment Share on other sites More sharing options...
Darin.Green Posted June 25, 2009 Share Posted June 25, 2009 It's good to see you're back up and running. Take care Quote Link to comment Share on other sites More sharing options...
