Grenco Posted June 23, 2009 Posted June 23, 2009 Hi all! I got a new question for you... Private Sub ACADApp_BeginCommand(ByVal CommandName As String) Dim Ssett2 As AcadSelectionSet Dim Blocks As AcadBlockReference Dim II As Integer Dim AttarrayY As Variant Dim Varatts As AcadAttributeReference Dim Viewobj_center(0 To 2) As Double Dim SelBlock(0) As AcadEntity On Error GoTo ErrorHandler Set Ssett2 = thisdrawing.ActiveSelectionSet thisdrawing.ActiveSelectionSet.Clear If CommandName = "ERASE" Or CommandName = "SELECT" Then 'If Ssett2.count < 2 Then ' Set Ssett2 = thisdrawing.SelectionSets.Add("XXX") ' Ssett2.SelectOnScreen ' End If For Each Blocks In Ssett2 If Blocks.ObjectName = "AcDbBlockReference" Then If ((Blocks.HasAttributes) And (Left(Blocks.Name, 3) = "G_B") Or (Left(Blocks.Name, 3) = "G_E") Or (Left(Blocks.Name, 3) = "G_I") Or (Left(Blocks.Name, 3) = "G_L")) Then thisdrawing.StartUndoMark AttarrayY = Blocks.GetAttributes For II = 0 To UBound(AttarrayY) Set Varatts = AttarrayY(II) If Varatts.TagString = "NOTE_2" And Varatts.TextString = "Checked" Then Viewobj_center(0) = Blocks.InsertionPoint(0) - 30: Viewobj_center(1) = Blocks.InsertionPoint(1): Viewobj_center(2) = 0 'Dim viewX As Double 'viewX = Viewobj_center(0) - 30 AutoCAD.ZoomCenter Viewobj_center, 80 G_ans_erase = MsgBox("Wilt u dit block hiernaast verwijderen?", vbYesNo + vbDefaultButton2, "Controle block-verwijdering") Set SelBlock(0) = Blocks If G_ans_erase = vbNo Then Ssett2.RemoveItems SelBlock 'thisdrawing.SendCommand ("undo" & vbCr & "1" & vbCr) End If AutoCAD.Update DoEvents 'MsgBox "Checked Item" II = II + 1 End If Next Else MsgBox "Geen Attributes aanwezig" End If Else MsgBox Blocks.ObjectName 'If Blocks.ObjectID = Then End If Next Blocks 'MsgBox CommandName End If Exit Sub ErrorHandler: If Err.Number = 13 Then Err.Clear Resume Next Else MsgBox Err.Number & Err.Description End If Ssett2.Clear End Sub It's a bit messy. But anyway. This is how i want it to work. 1. User selects items on screen like normal autocad (no command active) 2. User pressed DELETE(button) or Erase command. 3. Filter activeselected objects in VBA. First if acadblock, then has attributes, then blockname. 4. See if an attribute his tagstring is "NOTE_2" and textstring "Checked" 5. When a attribute is "Checked" there is a choice for the user to delete or keep the object. When he clicks KEEP object, I want to delete the current checked block from the activeselection set. But the activeselectionset is READ ONLY. So I cant delete it from there. I've put the activeselection in an other name (ssett2) wich I can change, delete, add, etc. And finaly delete my filtered object from my drawing. 6. When the routine is ended. The DELETE/ERASE command is still deleting the activeselection set. How can i bypass this? Deleting the activeselectionset isnt an option because it is read only?! How can I abort this command to happen?? Thanks for your ideas Quote
Grenco Posted June 30, 2009 Author Posted June 30, 2009 --- New topic --- http://www.cadtutor.net/forum/showthread.php?t=37771 Quote
