ikaross Posted June 22, 2009 Posted June 22, 2009 Summary:Error Heidi Module Load Error al editar archivo DWGDescription:Configuración del Desktop: Sistema Operativo: Windows XP Professional con SP3. INTEL® CORE 2 CPU E8400 3.00 GHZ 4 GB DE RAM. HARD DISK 320 GB. Aplicación: Autocad MAP 3D 2008 con Service Pack 1. Resumen del problema: Al realizar edición en archivos DWG en Autocad Map 3D 2008 aparece el siguiente error (recurrente cada 20 minutos a veces se puede trabajar 3 horas): "The configured Heidi driver cannot be loaded. Switching to default software driver" Inmediatamente se Acepta y sale el sgte mensaje: "Error Loading Heidi Module - c:\archivos de programa\autocad map 3d 2008\drv\direct3d9.hdi" Luego vuelve a salir la primera pantalla y nuevamente esta. Y as Quote
oscardd Posted August 11, 2009 Posted August 11, 2009 hi... sorry my english. I´m from Uruguay, use Autocad 2010 english version. I have the same problem... when i apply materials to some solids form in 3D Modeling: "The configured Heidi driver cannot be loaded. Switching to default software driver" If you or someone else have any idea... thanks!!! Quote
ReMark Posted August 12, 2009 Posted August 12, 2009 These types of errors may occur because the device driver file search path in AutoCAD is set to an incorrect path or the driver folder is corrupt. You may have to reinstall the display drivers. Quote
