are things you put in lisp case sensitive? like layers, variables, names, ect?
Variables & functions are not case sensitive.
I'd have to play around with Layers a bit to experiment.
If you set a variable to something and you check to see if it's that thing it's case sensitive. ie if you (setq variable1 "T") then run the check (= variable1 "t") that will return nil.
Just like to point out, I was referring to variable names not being case-sensitive... :P
Lol dont worry Lee i know 8)
