how to Pick the Value of Volume ?
ashish_mohekar
commanding line expression like this..
command : volume
select objects :
command using for volume output _massprop
question is : How to pick the Value From Text Window using lisp programming ?
give the small Lisp Programming ...... for above task
here the example of text window ;;;;
_massprop
Select objects: 1 found
Select objects:
---------------- SOLIDS ----------------
Mass: 59.6
Volume: 59.6Bounding box: X: 11.3 -- 17.6
Y: 3.4 -- 8.4
Z: 0.0 -- 1.9
Centroid: X: 14.5
Y: 5.9
Z: 1.0
Moments of inertia: X: 2280.9
Y: 12745.2
Z: 14878.9
Products of inertia: XY: 5101.7
YZ: 339.5
ZX: 830.2
Radii of gyration: X: 6.2
Y: 14.6
Z: 15.8
Principal moments and X-Y-Z directions about centroid:
I: 139.5 along [1.0 0.0 0.0]
J: 214.1 along [0.0 1.0 0.0]
K: 316.8 along [0.0 0.0 1.0]
Write analysis to a file? [Yes/No] :
So you want the area of an item?
"vla-get-Area areaselect" is what you would use as in
 (defun c:hi ()
(vl-load-com)
(princ (strcat "The area is " ( rtos (vla-get-Area (vlax-ename->vla-object (car (entsel)))) 2 0)))
No, I want to extract the volume from 3d model.
& your last programe not running succesfully.
It works fine for me, tho it dosnt have error handly it was a cut and paste sorta a job,If u dont select an item, it fails
Why not use the
"_MEASUREGEOM" command?
or cheesy version
(defun c:hi ()
 (command "_MEASUREGEOM" "ar" "o" pause //)
I have using 004, there is no command give the solution on 2004 platfrom only , or give idea to extract the value for text window e.g. massprop command..
The MASSPROP command has the option to export his report to a file; it is a simple, TEXT type file with no formatting. So the solution is to have that file generated and open it from your AutoLISP function and locate inside the volume line; split string by “:” and done!
The syntax of this file is constant.
Mr. msasu, send the small lisp programming file ...
i have only enter the single command & i want to only single output ... thru your lisp programming file. which is only volume ???
This?
(defun c:vol (/ ss vol)
 (vl-load-com)
 (if (setq ss (ssget '((0 . "3DSOLID"))))
     (setq vol
       (apply '+
         (vl-remove-if
           'vl-catch-all-error-p
             (mapcar
               (function
                 (lambda (x)
                   (vl-catch-all-apply
                     'vla-get-volume (list x))))
               (mapcar 'vlax-ename->vla-object
                 (vl-remove-if 'listp
                   (mapcar 'cadr (ssnamex ss))))))))
     (princ (strcat "\n<< Total Volume = " (rtos vol 2 2) " >>"))))
 (princ))
Please try this - no error protection added:
(defun ListVolume( / theSolid ReportFile InputLine theVolume )
(if (setq theSolid (ssget ":S" '((0 . "3DSOLID"))))
  (command "_MASSPROP" (ssname theSolid 0) "" "_Y" (setq ReportFile (strcat (getvar "TEMPPREFIX") "TempReport.MPR")))
  (if (setq ReportFile (findfile ReportFile))
    (setq ReportFile (open ReportFile "r"))
    (while (and (setq InputLine (read-line ReportFile))
                (/= (substr InputLine 1 7) "Volume:"))
    (setq ReportFile (close ReportFile))
    (setq theVolume (distof (substr InputLine 26)))
theVolume
Call it as (ListVolume) into your routine.
