too many arguments error on lsp anyone know why
yes i know this could be written better 20 different ways and if someone would like to go ahead. If not if someone could tell me how to fix it so it will run and preform the desired results that would be great!
(defun C:freeze)
(command "_.layer" "Freeze" "structural")
(command "_.layer" "Freeze" "sahco")
(command "_.layer" "Freeze" "jwmc")
(command "_.layer" "Freeze" "tbf")
(command "_.layer" "Freeze" "3d piping")
You have an extra ")" on your first line, or missing and extra "(" on your first line.
(defun c:freeze ()...
knew it was simple thanks
[color=red](defun C:freeze)[/color]
chelsea, please compare
[color=red](defun C:freeze ()[/color]
following on from JeepMaster's post, you may need to add "" to the end of each line where you are freezing the layer. It will allow each line of code to complete and exit cleanly
(command "_.layer" "Freeze" "structural" [b][color="Navy"]""[/color][/b])
thanks, will add that!
Hi,
Try this instead.
(command "._Layer" "Freeze" "structural,sahco,jwmc,tbf,3d piping" "")
Have a good one.
Shawndoe
knew it could be even simpler... thanks
