hello
i'm starting with autocad lisp
i've learnd that you start a routine with
(defun c:name ....)
but now i've found a program that start with
(defun cb:hdis (/ld)
this comes back with the variables
if (= (type cb:ld) 'str
i understand the meanig of this code exept what te cb: means
can someone tell me what's the difference between defun c: and defun cb:
By analogy to this article, I have written article on use of a code from a forum in Russian, where has a little expanded the description.
As I not so well know English, therefore I will take advantage of machine translation. I hope, it will be clear, and if is not present, me will correct.
Command or function?
To begin with it is necessary to be defined, that at us: a command or function?
It is a little theory.
In the description practically any code there is such line, as
(defun …
And then after her something there it is written. And so that there is written and is a function name.
If the first symbols are C:, function is ready to a call from a command line. If such is not present to cause function it is necessary, concluding her name in parentheses.
For example, there is a function
(defun c:test () )
It to cause since a command line it is possible directly:
Command: test
Also actions
And here the such:
(defun test () )
It will be possible to cause only so:
Command: (test)
Also actions .
From the point of view of AutoCAD'a it is 2 different modules
In your case it is function and it needs to be caused so: (cb:hdis)
I believe I've seen that lisp before. "cb:" doesnt actually do anything. That code is just a function. if you were to type in "hdis" as a command it wouldnt do anything. but if you were to use it like this (cb:hdis) it would run. Why they named it that way is unknown to me but im sure they had their reasons.
:P Too little too late it seems. Good description VVA
Nice once VVA, but, yes, I believe its just irresponsible function naming... :glare:
I wouldn't bet on it... I do this all the time. Useful for identification.
I agree. I use function name prefixes all of the time. My preference is to use an underscore delimiter , but a colon is just as valid. My $0.02 -David
You mean using the function syntax as a prefix for sub_routines - I suppose its good for reference, but the function begins with a c..: I suppose it could confuse the LISP novice...:P
Possibly, but still nothing wrong with it. I do this sometimes within the same file. Say my file (and main function is named) CHTXT - i might name my internal functions things like:
(defun chtxt:myfunc ()
 (blah_blah)
Of course, like David says, just my 2¢.
