I don't get it? So AutoNum v3 has been updated?
Yes. There were a few formatting issues with certain functions, and I have made a few improvements to the coding following suggestions made. :)
  • Replies 126
  • Lee Mac
    43
  • AQucsaiJr
    34
  • fuqua
    19
  • tony barretto
    5
Posted Images
Geese... Going above and beyond with this AutoNum command file... I thought the first version you created was perfect for what I was asking for... You just won't quit making it better and better... What did I start... lol :)
Thanks for the perfections and improvments!
Well, if there is a bug that is found, it has to be sorted - and of course any suggestions that I like are incorporated :)
I applaud, and thank, you for your dedication to support the files you create!
I have updated AutoNum in the archive to include a few more minor adjustments. My thanks to CAB at theSwamp.org for his continued help. :)
With the excellent help of CAB over at theSwamp.org, AutoNum and NumInc have been combined into one program to offer an alternative.
Try it here.
Lee
Awsome!! Looks great!!
Try it here.
Lee
:shock:
but i have a suggestion if u dont mind.
Try it here.
Lee
Lee,
I have not tried the new version as of yet, But when I went to the thread you had two versions listed v3 & v4. I assume the new version is v4 or is there another reason you have the two versions still listed.
The Buzzard
Lee,
Tested AutoNum versions 3 & 4 and it did not work like your NumInc.lsp where you could select an attribute.
So I saw that you had a version 7 for the NumInc and I gave it a try. It gave me this error when replacing an attribute.
Command:
Command:
Command: _appload NumInc V7.lsp successfully loaded.
Command:
Number Increment Loaded, type "NumInc" to invoke...
Copyright © April 2009, Lee McDonnell.
Command:
Command: NUMINC
<<Exit>> [C]urve Aligned, [space] = Rotate ACW, [Tab] = Rotate 90 [T]oggle Count
[shift] + [space] = Rotate CW, [shift] + [Tab] = Mirror Rotation, [R]eplace
Select Text, MText or Attribute << Hit Enter to Exit >>: Regenerating model.
Command:
Error: Automation Error. Object was erased
Command:
The last version no. 5 worked great with regard to replacing the attributes. Did not get this error.
Thought you should know about it.
See if this works for attributes.
There was a bug in there. :)
Excellent CAB!
Thats the ticket. Now the program is very versatile. I need to get a handle on the latest versions. So many to try out, It gets confusing.
Thanks,
The Buzzard
Should I replace my old v4.lsp for this new v4.lsp?
Yes, it is the same file but with the fix for attributes.
Hello from Brandon, Florida:)
Lee,
The Buzzard
Yes, I kept the two different versions in the Archive, as V4 was re-written by CAB to incorporate NumInc and AutoNum. Whereas V3 keeps AutoNum separate.
Yes, to do with the visibility of the Text I think - I put it invisible when created, so that the user did not see it flash at the origin when created.
Yes, I shall update the Archive with this new fix.
That makes more since... I thought it was an additional LISP when I seen the name change... Thanks!
I have made it clearer in the archive now - to prevent more confusion... :oops:
  • 2 weeks later...
When using the "Pick Each Insert" option, is there a way to have it place on an osnap? I am having no luck doing this. I can place the text fine, however I would like to be able to place it on like an end point of a line. Maybe I am missing something?
