Wow... Too Cool... You can make a write up about this one now too!!! They will both be very useful to me... I can't thank you enough... I hope, sometime down the road, I can figure out how to make these programs for people in, what was, my predicament... Thank you, very much, for the help.
Thank you for your kind message AQucsaiJr - I get enjoyment from writing the programs, and also learn a lot from making them, so I don't mind if someone else can benefit in the process also. o:)
  • Replies 126
  • Lee Mac
    43
  • AQucsaiJr
    34
  • fuqua
    19
  • tony barretto
    5
Posted Images
Well I thank you for sharing this talent you have with me and the rest of the members here. :)
I have a suggestion for your NumInc file... The AutoNum files has an option of changing the insertion point before placement... I think it might be useful to have that option on the NumInc as well... I know I will use this feature often in the AutoNum.
Nice idea, but the problem is that the NumInc function also has an option for Curve-Alligned Text - which doesn't work too well with different Justifications. :(
Oh ya... Forgot about that... Oh well... It is still a very good and usable program... Thanks for providing the link... I have already added these two text creation commands to my custom files menu.
Nice one :)
Check out the other LISP's in the Archive - there are quite a few useful ones in there :)
I may have found a problem... I keep getting this error message with the AutoNum LISP:
Command: AutoNum
Select Base Point:
the dialog box appears... I fill in the information... And when I select a point, that message comes up... I would send you the screen shot of the dialog box filled in but I don't know how.
Well I just unoaded the LISP file from the CUI and reloaded it and now it seems to work again... Maybe Auto-CAD messed up... I will keep you informed.
Ok, I thought I'd covered all bases, but yes, keep me posted :wink:
holy christ dude, you aced the program ! :D just WOW
thank you so much mate :)
Updated to Version 3, to include an Angle Pick and other bug fixes. :):):)
hmm just got the chance to try this one out mate, but im getting a error when trying to use the lisp. says "error loading number increment"
is there something special i need to do with the other file ?
All seems to work fine for me :unsure:
A few things that could cause your error:
  • Make sure that the DCL is saved in your AutoCAD search path.
  • Do not rename the DCL file, as this will cause an error.
I can't really think of much else that could go wrong.
Lee
Lee
search path of the dcl did the trick mate ! :D thanx
Holy crap Lee.... I didn't think perfection could be tweaked... I like it... Thanks!
