lotfyxp Posted December 5, 2009 Posted December 5, 2009 This would be almost perfect if it had an option to do an ( above a default elevation option). That would allow for a floor by floor finish floor dimension. Just throwing that out there. Thanks Lee. Damn you do good work. Quote
Lee Mac Posted December 5, 2009 Author Posted December 5, 2009 Thanks I wrote this as an alternative version.. not sure if it is what you are after: http://www.cadtutor.net/forum/showthread.php?t=37271 Lee Quote
fabcad Posted September 7, 2010 Posted September 7, 2010 Hello Lee Mac, With MacAlignm there is no option offset. Thanks, Fabcad Quote
Lee Mac Posted September 7, 2010 Author Posted September 7, 2010 Hello Lee Mac, With MacAlignm there is no option offset. Thanks, Fabcad And I suppose you want one... Quote
fabcad Posted September 8, 2010 Posted September 8, 2010 Hello Lee Mac, Very difficult the shakespeare language. Your dynamics functions are revolutionary for my daily work. Yes I want this option, please, because I do this work every day in my maps, if you want to release your fonction. Very thanks, Fabcad Quote
Lee Mac Posted September 12, 2010 Author Posted September 12, 2010 Code in Archive completely rewritten Quote
fabcad Posted September 12, 2010 Posted September 12, 2010 Hello Lee Mac, Big thanks for your impressive work, Best of the best, Fabcad Quote
Lee Mac Posted September 12, 2010 Author Posted September 12, 2010 Thanks Fabrice, I'm glad you like it Quote
zemoe1 Posted June 27, 2011 Posted June 27, 2011 Hi Lee, After seeing your post and your excellent lisp routines on the cadtutor site...I have a question...is it possible for the Align text routine to do multiple lines of text via a crossing or window of that text... thnx for all the hard work, Z 8-) Quote
Lee Mac Posted June 27, 2011 Author Posted June 27, 2011 Thanks zemoe After seeing your post and your excellent lisp routines on the cadtutor site...I have a question...is it possible for the Align text routine to do multiple lines of text via a crossing or window of that text... The program in this thread (CurveAlignedText) will only align a single text object, although I have also written this program which will align any number of objects to a curve - perhaps it is more suitable. Lee Quote
notview Posted October 12, 2012 Posted October 12, 2012 Hi Lee Mac, can you make (e.g. CREEK) into single text C R E E K and align single letter into curve. There are options for increasing/decreasing of font size, text spacing, width factor, & offset from curve. Thanx for good work!! notview Quote
Lee Mac Posted October 12, 2012 Author Posted October 12, 2012 can you make (e.g. CREEK) into single text C R E E K and align single letter into curve. There are options for increasing/decreasing of font size, text spacing, width factor, & offset from curve. Slinky Text Thanx for good work!! Cheers! Quote
notview Posted October 28, 2012 Posted October 28, 2012 Slinky Text Cheers! Great programmer!! Thank you Lee Mac for Slinky Text!! Quote
notview Posted November 1, 2012 Posted November 1, 2012 Lee Mac, Good Day! It is better if you add an option increasing and decreasing of Font Size (in CurveTextV1-4.lsp). Thanks for your good work!! Quote
Lee Mac Posted November 1, 2012 Author Posted November 1, 2012 Great programmer!! Thank you Lee Mac for Slinky Text!! Thank you It is better if you add an option increasing and decreasing of Font Size (in CurveTextV1-4.lsp). In the current version of the program the text size is dependent on your setting of the TEXTSIZE System Variable. Quote
yathishkumar Posted January 2, 2015 Posted January 2, 2015 Hi Lee sir align text to curve mirror option and rotation with all degree could modifie Thanks Quote
Lee Mac Posted January 3, 2015 Author Posted January 3, 2015 Hi Lee siralign text to curve mirror option and rotation with all degree could modifie Thanks Hi yathishkumar, It is already possible to specify an arbitrary rotation by typing 'R' or 'r' whilst aligning the text, or through the Settings menu. Please ensure you are using the latest version of the program, which may be found here. Lee Quote
yathishkumar Posted April 5, 2015 Posted April 5, 2015 Hi sir, i have a problem. while i select the curve osnap is not working on curve. could you able to update. on block align,align object to curve & align text curve. i hope it maybe help us. thanks. thanks Quote
Lee Mac Posted April 5, 2015 Author Posted April 5, 2015 Hi sir,i have a problem. while i select the curve osnap is not working on curve. could you able to update. on block align,align object to curve & align text curve. i hope it maybe help us. thanks. thanks Due to the use of a grread loop to generate the dynamic visual effect in these programs, all standard drawing aids (Object Snap, Orthomode, Tracking etc.) are unavailable when positioning objects using these programs. As I've demonstrated with my GrSnap function, it is possible to imitate the functionality of Object Snap, however, this utility would not be compatible with programs such as my Align Text / Object to Curve programs, as these programs are continuously repositioning the objects in question - therefore, the utility would continuously snap to the object being positioned before any surrounding objects. Lee Quote
yathishkumar Posted April 5, 2015 Posted April 5, 2015 Thank u sir, for u r reply. thanks yathishkumar Quote
